![]() | Home > Technical > help! more headlight issues! |
| Miggit Member Since: 09 Mar 2017 Location: Milton Keynes Posts: 72
Of cause LED don't do the system any favours as they are a little more voltage critical... there is not much scope for dim led's in less than a volt they can go from fully on to totally off... at least a filament light bulb will do it's very best to glow no matter how poor the voltage gets. RRC 2.4 TD... it's either a stretched 90 or shrunken 110!! ML 270CDI |
| JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190
Whether the failure is, it is connected to all of the lights. Left and Right Headlights are on separate fuses so take a look at the wiring diagram and find the common failure point.
Is it blowing fuses or just not working? As a temp solution hook up a cheap set of fogs to a switch but not using any of the Land Rover wiring. They can be a get to work/home until you can fix it properly. This may not be legal way to drive, it isn't any worse than other car users on the road these days. ![]() |
It's highly unlikely that 4 separate circuits have failed simultaneously, it's more likely to be the 2 most common things... the earth or the fact that it's made by Land Rover and you got it wet... afterall they are trying to follow in the tradition that they gained with Lucas components.. they must spend days try to find components of equally poor quality
And I don't know why I'm laughing... my car is riddled with Lucas parts...D'OH! ML 270CDI |
| monk Member Since: 02 Mar 2017 Location: east yorkshire Posts: 39
Right! Basically i gave up, id had enough and called an auto electrician, if this makes any sense to anyone, the live feed back to the switch had failed somewhere he couldnt find where he said it would be a pain to find but said it would be a large connector block probably and a bad connection so just fed the live from somewhere else and chopped the old feed off!
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21039
Chopped the old feed off.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
Glad you got it sorted and hope it wasn't too expensive
The joys of Defender ownership. |
60quid! But i must have spent 4+ hours trying to find it, i know the guy who fixed it until yesterday couldnt get his number, know hes been an auto spark 25+ years so he knows what hes doing!
| All times are GMT |
.gif)
