Home > Technical > help! more headlight issues!
Page 2 of 2 <12
I sympathise, I really do. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #610178 17th Mar 2017 9:09pm
Miggit
Shocked So LR have improved the bad earth fault then... may years ago bad earths would result in orange lights, we found the best way to cure was to run the headlamp earth's direct to the engine block, or battery, depending on how involved you want to get.. Now it looks like LR have sorted the orange light issue and they are now either on or off Shocked
Of cause LED don't do the system any favours as they are a little more voltage critical... there is not much scope for dim led's in less than a volt they can go from fully on to totally off... at least a filament light bulb will do it's very best to glow no matter how poor the voltage gets. RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
Post #610313 18th Mar 2017 4:00pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
Whether the failure is, it is connected to all of the lights. Left and Right Headlights are on separate fuses so take a look at the wiring diagram and find the common failure point.
Is it blowing fuses or just not working?
As a temp solution hook up a cheap set of fogs to a switch but not using any of the Land Rover wiring. They can be a get to work/home until you can fix it properly. This may not be legal way to drive, it isn't any worse than other car users on the road these days.
Post #610341 18th Mar 2017 5:58pm
Miggit
It's highly unlikely that 4 separate circuits have failed simultaneously, it's more likely to be the 2 most common things... the earth or the fact that it's made by Land Rover and you got it wet... afterall they are trying to follow in the tradition that they gained with Lucas components.. they must spend days try to find components of equally poor quality Rolling with laughter
And I don't know why I'm laughing... my car is riddled with Lucas parts...D'OH! Sad RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
Post #610385 18th Mar 2017 7:34pm
monk
United Kingdom 2000 Defender 110 Td5 DCPU Java Black (black Hood)
Right! Basically i gave up, id had enough and called an auto electrician, if this makes any sense to anyone, the live feed back to the switch had failed somewhere he couldnt find where he said it would be a pain to find but said it would be a large connector block probably and a bad connection so just fed the live from somewhere else and chopped the old feed off! Rolling Eyes
Post #610677 19th Mar 2017 7:37pm
Chopped the old feed off. Shocked ____\We|Will|Win/___
Post #610688 19th Mar 2017 7:55pm
Balvaig
Glad you got it sorted and hope it wasn't too expensive Big Cry
The joys of Defender ownership.
Post #610694 19th Mar 2017 8:09pm
monk
60quid! But i must have spent 4+ hours trying to find it, i know the guy who fixed it until yesterday couldnt get his number, know hes been an auto spark 25+ years so he knows what hes doing! Thumbs Up
Post #610775 19th Mar 2017 11:13pm
Page 2 of 2 <12
