Home > Maintenance & Modifications > Spare wheel carrier spacers for 265+ tyres
jk84
I'm fitting a 265 wheel to the rear spare carrier. To prevent it from fooling with the rear wiper I needed to leave the spacers a bit distanced from the carrier as per below picture. I was able to tighten up the wheel bolts fine, but now I'm thinking I should perhaps get another set of spacers instead of leaving a gap between the carrier and the spacers. Opinions?
 MY15 Aintree 110 SW - for sale - https://www.defender2.net/forum/topic82781.html
MY16 Santorini 90 HT - sold
Post #609186 13th Mar 2017 8:06pm
zsd-puma
I expect it'd be fine like that, but you could always just pack behind it with a few washers if you wanted.
Post #609188 13th Mar 2017 8:16pm
jk84
Cheers, thought it should be alright but wanted to sanity check. MY15 Aintree 110 SW - for sale - https://www.defender2.net/forum/topic82781.html
Post #609228 13th Mar 2017 9:47pm
bankz5152
I removed the wiper cover, stops it fouling. On my 110 however I just used some old steel wheel nuts to spacer the tyre out a little.
Post #609405 14th Mar 2017 3:15pm
jk84
Neat idea with the steel wheel nuts bankz. I used few washers in the end as zsd suggested and it worked a treat. MY15 Aintree 110 SW - for sale - https://www.defender2.net/forum/topic82781.html
Post #610046 17th Mar 2017 12:39pm
