![]() | Home > Puma (Tdci) > Heated Filter |
dfilipu Member Since: 06 Feb 2016 Location: Savoie Posts: 5 ![]() ![]() ![]() |
I stay in alpine ski resort. Here we got a special diesel for winter ( filtration capability to -20°C ) but the defender is very sensible. So I use same pad for heat my filter. It's really effective but I always put a new filter in the cubby box. If old filter is colmated I change it and go. If you need power, pad can't heat diesel fast enough.
If pression is too low ( paraffin in filter ) light appear in dashboard. You must use ODB apps to remove default code and the light. |
big110 Member Since: 02 Nov 2016 Location: Pinner Posts: 374 ![]() ![]() ![]() |
what heater pad would be recommended for the filter?
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
I wish i could read that website
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
Or use this kit. Fully prewired with timer relais, silicone 100W heater. All automotive grade and waterproof.
https://www.nakatanenga.de/elektro/geraete...und-taster WANTED: SII or SIII in max 1.5k |
sent a PM to you, Naka
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1066 ![]() ![]() ![]() |
In the past, wasn't it standard practice to add a little petrol in the winter to prevent problems? Is it still done? What problems could it cause?
I use Wolverine Fh50 model and a heated cable on fuel pipe. But I think it's better to use only a fh100 model. The 50 is too small and you must ride slowly to give Time to heat fuel.
Yes in Old car you can add à small ratio of petrol but now with very high pressure injector you must special additive. |
