Home > Puma (Tdci) > Heated Filter
hornet
Heated Filter
For those of you who expect Diesel-problems due to brawn caused through low ambient temperatures, I did a heating trial, shortly described now.
I used a trace heating for 12V, 8m heating cable with 120W (~ € 35,--) and wrapped it around a standard filter-element, see picture.
I filled it up with 250ml of Diesel, measured Diesel-temperature inside the filter and surface temperature of heating-element (IR) continously. Diesel temperature was 7°C, filter ~ 20°C before start, I did not wait for balance. After start the temperature of the element-surface reached 60° within seconds and was able to heat up the diesel after 15 minutes to a temperature of 45°C, respectively close to 60°C diesel at 80°C surface after another 5min (20min at all).
The trial shows, that thera are "quick and dirty" solutions for the winter-filter-problems. Performance can be raised of course if you care for a suitable isolation with neoprene materials such as "Armaflex" or similar. I guess that a preheat-phase of ~10min without and another 5min with running engine would be a good start. Have the 10A in mind!
Post #598775 3rd Feb 2017 10:18am
dfilipu
France 2012 Defender 110 Puma 2.2 SW Alpine White
I stay in alpine ski resort. Here we got a special diesel for winter ( filtration capability to -20°C ) but the defender is very sensible. So I use same pad for heat my filter. It's really effective but I always put a new filter in the cubby box. If old filter is colmated I change it and go. If you need power, pad can't heat diesel fast enough.
If pression is too low ( paraffin in filter ) light appear in dashboard. You must use ODB apps to remove default code and the light.
Post #599149 4th Feb 2017 10:51pm
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
what heater pad would be recommended for the filter?
Post #609406 14th Mar 2017 3:21pm
hornet
Post #609414 14th Mar 2017 4:15pm
big110
I wish i could read that website Big Cry
Post #609416 14th Mar 2017 4:20pm
dorsetsmith
Post #609417 14th Mar 2017 4:27pm
nakatanenga
Germany
Or use this kit. Fully prewired with timer relais, silicone 100W heater. All automotive grade and waterproof.
https://www.nakatanenga.de/elektro/geraete...und-taster WANTED:
SII or SIII in max 1.5k
Post #609421 14th Mar 2017 4:39pm
big110
sent a PM to you, Naka
Post #609430 14th Mar 2017 5:58pm
AMBxx
In the past, wasn't it standard practice to add a little petrol in the winter to prevent problems? Is it still done? What problems could it cause?
Post #609580 15th Mar 2017 10:13am
dfilipu
I use Wolverine Fh50 model and a heated cable on fuel pipe. But I think it's better to use only a fh100 model. The 50 is too small and you must ride slowly to give Time to heat fuel.
Yes in Old car you can add à small ratio of petrol but now with very high pressure injector you must special additive.
Post #609669 15th Mar 2017 7:33pm
