Home > Technical > Help. , sounded like a bag of old spanners now won't start??
NCTT
Hi all , any ideas
My 2010 utility made a few funny noises , like a really loud rattling , almost someone like a bag of old spanners in the bonnet
It stopped but thought nothing more of it. But it's happened again today and only just started , was just clicking there was power but not turning over .
Luckily it did start and it's now back on the drive ,I've got a long run next weekend in it and something's not right.
Any mechanics out there hazzard a guess what it may be pleas?
Thanks so much in advance 🙏🙏
Post #608876 12th Mar 2017 3:46pm
NCTT
if this is in the wrong section, culd a mod please re ost in technical pls ? Thumbs Up
thanks
Post #609083 13th Mar 2017 9:20am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Probably loose injector clamp?
Have a look at the injectors when running, see if a couple are bobbing up and down. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #609100 13th Mar 2017 10:25am
NCTT
oh right , ok thanks , so this would be an easy fix ?
it sounded dreadful ?
Post #609101 13th Mar 2017 10:31am
ian series 1
Yes, straightforward you will need to remove a few part around the injector to get to the bolt.
If it is the injector you should really replace the washer and seals, but if you need it just to get you out of trouble nip the bolt down, NOT tight, think it's around 6NM?
It's the only thing I can think of that makes a really nasty noise?
And cause a starting problem.
Try a search on here for "loose injector clamp" there was a video posted recently.
Common problem on the TDCI 80" 80" 86" 88" 90"
Post #609108 13th Mar 2017 10:49am
NCTT
that brilliant, thanks very much indeed !
will hopefully get me out of trouble
top man
Post #609110 13th Mar 2017 11:14am
zsd-puma
The new bolts are cheap enough from Land Rover Dealers (you need two, as the injectors are clamped in pairs.)
but DO NOT buy the washers from Land Rover, they're a complete rip off, at about £18 each! Shocked
Just get a set of 4 washers off ebay for a 2.4 transit, or your local diesel injection specialist. It's worth getting new oil seals for the injectors if you're taking them out to change the washers.
It's a straight forward job, it's all easy to get at.
Post #609115 13th Mar 2017 11:49am
NCTT
thanks , yes seems there is a very healthy mark uyp there as its land rover !
Post #609117 13th Mar 2017 11:52am
zsd-puma
To be fair even Ford wanted about £9 each for them! Citroen were £7 each. (the Citroen Relay uses the 2.2 Puma engine too)
Post #609181 13th Mar 2017 7:59pm
NCTT
TBH if its only these ive got to sort I don't mind
the noise was horrific , sounded the the engine has exploded !
Post #609366 14th Mar 2017 1:21pm
zsd-puma
Like that?
Another contender could be a knackered crank damper pulley.
Post #609452 14th Mar 2017 8:08pm
NCTT
hmmm I cant open the vid , but thanks fella
will try tonight at home
ta vm
Post #609553 15th Mar 2017 8:17am
NCTT
well , after all that it was the starter motor , AGAIN !
but thanks for tyhe help chaps , odd one
Post #611130 21st Mar 2017 2:41pm
ickle
There's a thread on here about that - faulty ignition switch keeping the starter engaged after its started????
Keith
Post #611203 21st Mar 2017 8:44pm
dgardel
Italy
Re: Help. , sounded like a bag of old spanners now won't sta
NCTT wrote:
Hi all , any ideas
....wrong answer... my bad Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #611345 22nd Mar 2017 10:40am
