![]() | Home > Technical > Help. , sounded like a bag of old spanners now won't start?? |
NCTT Member Since: 07 Apr 2008 Location: ESSEX Posts: 229 ![]() ![]() |
Hi all , any ideas
My 2010 utility made a few funny noises , like a really loud rattling , almost someone like a bag of old spanners in the bonnet It stopped but thought nothing more of it. But it's happened again today and only just started , was just clicking there was power but not turning over . Luckily it did start and it's now back on the drive ,I've got a long run next weekend in it and something's not right. Any mechanics out there hazzard a guess what it may be pleas? Thanks so much in advance 🙏🙏 |
if this is in the wrong section, culd a mod please re ost in technical pls ?
![]() thanks |
oh right , ok thanks , so this would be an easy fix ?
it sounded dreadful ? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Yes, straightforward you will need to remove a few part around the injector to get to the bolt.
If it is the injector you should really replace the washer and seals, but if you need it just to get you out of trouble nip the bolt down, NOT tight, think it's around 6NM? It's the only thing I can think of that makes a really nasty noise? And cause a starting problem. Try a search on here for "loose injector clamp" there was a video posted recently. Common problem on the TDCI 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
that brilliant, thanks very much indeed !
will hopefully get me out of trouble top man |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
The new bolts are cheap enough from Land Rover Dealers (you need two, as the injectors are clamped in pairs.)
but DO NOT buy the washers from Land Rover, they're a complete rip off, at about �18 each! ![]() Just get a set of 4 washers off ebay for a 2.4 transit, or your local diesel injection specialist. It's worth getting new oil seals for the injectors if you're taking them out to change the washers. It's a straight forward job, it's all easy to get at. |
thanks , yes seems there is a very healthy mark uyp there as its land rover !
To be fair even Ford wanted about �9 each for them! Citroen were �7 each. (the Citroen Relay uses the 2.2 Puma engine too)
TBH if its only these ive got to sort I don't mind
the noise was horrific , sounded the the engine has exploded ! |
Like that? Another contender could be a knackered crank damper pulley. |
hmmm I cant open the vid , but thanks fella
will try tonight at home ta vm |
well , after all that it was the starter motor , AGAIN !
but thanks for tyhe help chaps , odd one |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
There's a thread on here about that - faulty ignition switch keeping the starter engaged after its started????
Keith |
....wrong answer... my bad Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
