![]() | Home > Td5 > A puzzling problem |
Does it sound like a ball bearing rattling around? And does the engine chirp when switched off? Ray
Were the crankshaft bearings checked? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Also has injector lash been set correctly? 2002 90 Td5 Station Wagon
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
Hello,
Thanks for taking the time to read and reply! In answer to your questions. it does sound like a marble rattling about in a box as it returns to idle and sometimes when its idling, other times its more like a diesel knock. I have not noticed it squeaking when turned off but I'll listen for it when I take it out later. -I'll try and record the noise if I can too. The crank bearings were inspected when the engine was stripped and the guy from the independent garage was quite happy with them-aside from the marking on the piston crowns he said that the condition of the engine parts was 'remarkable' for a 145k engine. The lash has been set three times, twice by garages and checked and set a third time by a friend. The injectors were coded too. Chris |
I'm no expert but has the common rail part of the fuel system been pressure checked? Could be a pinhole leak bypassing an injector.
I have just managed to get a short video of it when its idling poorly and idling normally, I have no idea how to upload them though!
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
When the injectors were replaced, we're they correctly coded in the ecu? V8 90...WIP
It's also worth checking the gauze filter in the fpr... V8 90...WIP
Video of the bad idle when hot
Video of it idling normally when cold |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1652 ![]() ![]() |
hmm bit of a good one
did you use new head bolts etc on the rebuild? we have had a similar issue on a disco and the ecu was failing. replaced with a good one from another car,coded up injectors etc poor remaps often lead to these strange symptoms as well |
Yes, it was all done with new bits, it has done this both on standard mapping and its had a different map tried on it to see if it was a firmware or mapping issue.
Alive tried a different ECU on it, but they weren't able to get it to reproduce the fault with either ECU. Its a very frustrating fault, and it gets increasingly bad the hotter it gets- this was after a quick blast down a few motorway junctions and back. Chris |
Could be the crank sensor. It sounds like it's hunting a bit 2002 90 Td5 Station Wagon
@grafty, its had a new crank sensor
My wife was just tickling the throttle to demonstrate it at its worst during the video...... It wasn't fully hot through so was still settling (eventually) Chris |
Has the timing been checked? 2002 90 Td5 Station Wagon
