![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Hi, I don't have any pics of mine as I didn't take any while doing it
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Rad666 Member Since: 21 Jun 2016 Location: North yorkshire Posts: 89 ![]() ![]() ![]() |
Did you use the side supports then or have you just made the clearance in the arch
I haven't used the side supports yet but do intend to when I get around to fitting them. The seats have been in for a couple of years now without the supports and I've had no problems yet but just for peace of mind I will fit them eventually. Ray
Thanks for the reply, just emailed yrm see if they fancy doing some plates
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
Yes, this is my truck. The inserts are 2 pieces, then seam sealed and rivered in place. There are a couple of awkward bends in there, used a small vice brake to do the bends. Primed, painted then installed. I added the support brackets once the seats are in. The set up is pretty solid. ![]() Click image to enlarge it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
![]() ![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777 ![]() ![]() |
H mmmmmmm, that sounds like a task for ...............
Finally got a few mins to put the rear door guard on, I'll keep it on until I put the new rear door on then decide if I want it on permanently or not
![]() Click image to enlarge ![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
An expensive day
![]() ![]() Click image to enlarge Downside is it hasn't solved my problem ![]() My build thread http://www.defender2.net/forum/topic17615.html |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
![]() What's the problem Ray? (Obviosly not the injectors ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Lots of black smoke
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1454 ![]() ![]() ![]() |
Oh dear Ray
Did you get any further with programming the injectors ? If all else fails get some rigger boots, bush hat and a "NO SMOKE NO POKE" sticker ![]() ![]() |
