Home > Maintenance & Modifications > Spray for rear crossmember
johnnyd
Hi All
Is there a recommended spray to make the rear crossmember look black again, it has surface rust appearing on it and looks ugly
JD 2008 TDCi 2.4 XS CSW
Post #605226 27th Feb 2017 12:49pm
JOW240725
I seem to have posted this several times now, but no actual experience of it, it just seems the best stuff I've seen posted on FB particularly. I will at some point be doing this myself.
Before
Buzzweld RCP primer
Buzzweld CIO
Buzzweld photo of finish
 James
Instagram @suffolk_rovers
Post #605227 27th Feb 2017 12:57pm
Stacey007
Under coat x 2
Sprayed
Then slapped some rust preventer on inside, and sprayed the holes with rust preventor
Post #605230 27th Feb 2017 1:06pm
zsd-puma
I rubbed mine down to shiney metal then zinc primed it and painted it with Upol satin black. Dinitrol 3125 inside of it.
Post #605231 27th Feb 2017 1:14pm
Romadog
Buzzweld RCP and CIO
Picture above in JOW240725's post shows best replication of factory finish Thumbs Up
Post #605316 27th Feb 2017 8:09pm
As zsd-Puma suggests in the last sentence of his post.
Make sure you protect what you can't see as well as painting the external area for asthetic reasons.
What you can't see is a lot more to worry about than what you can see. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #605318 27th Feb 2017 8:22pm
arran jones
Hello,
Im.thinking of getting that dinitrol 3125, does it have to be sprayed with a gun, or is there a trigger on.the top!!
I have surface rust on the rear cross member, hopefully this will stop it, and then will get some black paint!!!! Thumbs Up
Post #605320 27th Feb 2017 8:27pm
You can get it in aerosol and with internal staws etc.on the Rejel site or via eBay. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #605327 27th Feb 2017 8:37pm
arran jones
Cool thanks Thumbs Up
This forum is great, so many helpfull people! Very Happy
Post #605330 27th Feb 2017 8:44pm
Thumbs Up There is standard straws and there are internal tubing ones that are long with a 90 degree angle spray pattern that sprays 108 degrees as you draw it back through internal components. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #605341 27th Feb 2017 9:20pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I used this. Looks factory fresh and hard wearing -
http://www.frost.co.uk/brands/eastwood/eas...-397g.html 1953 80"
1987 mini city e
2011 90"
Post #605385 27th Feb 2017 10:33pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
I sanded down the crossmember removing as much old paint / rust as possible. Used DP90 2 part epoxy primer, then topcoat of Trim Black.
So far, it's held up well. I have no doubt it won't be the last time I have to do it. Once you have rust, it's never going away Evil or Very Mad It's just a matter of how much you can slow it down Laughing
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #605409 27th Feb 2017 11:17pm
zsd-puma
re. the dinitrol, you can get it in a Shultz can and use a gun or it's available in aerosol cans with extension wands available for them. I think i used the gun on this, but the aerosols would do it too, they;re also good for when you need more control, like spraying it into a narrow crack.
TBH while i used Upol satin, any old satin black will match the factory finish, it's the prep work you do underneath that makes the difference.
Post #605441 28th Feb 2017 12:46am
johnnyd
OK I have my Buzzweld kit of primer and satin, here are some pics of the member, how much prep work do i need to do on it, is it just a bit of sanding to get rid of the pitting, ie I don't need to get it back to silver with no paint on it?
Its 2008 not a P by the way Very Happy
Thanks
JD
Post #620520 30th Apr 2017 12:17pm
sako243
According to the Buzzweld website you don't need to take it back to bare metal. However, if you have the time why not. No rust then... Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #620530 30th Apr 2017 1:25pm
