Home > Maintenance & Modifications > Spray for rear crossmember |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7890 |
I seem to have posted this several times now, but no actual experience of it, it just seems the best stuff I've seen posted on FB particularly. I will at some point be doing this myself.
Before Buzzweld RCP primer Buzzweld CIO Buzzweld photo of finish Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
27th Feb 2017 12:57pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3720 |
Click image to enlarge Under coat x 2 Click image to enlarge Sprayed Click image to enlarge Click image to enlarge Then slapped some rust preventer on inside, and sprayed the holes with rust preventor |
27th Feb 2017 1:06pm |
Click image to enlarge I rubbed mine down to shiney metal then zinc primed it and painted it with Upol satin black. Dinitrol 3125 inside of it. |
27th Feb 2017 1:14pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1747 |
Buzzweld RCP and CIO
Picture above in JOW240725's post shows best replication of factory finish |
27th Feb 2017 8:09pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20121 |
As zsd-Puma suggests in the last sentence of his post.
Make sure you protect what you can't see as well as painting the external area for asthetic reasons. What you can't see is a lot more to worry about than what you can see. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 Last edited by custom90 on 27th Feb 2017 8:36pm. Edited 1 time in total |
27th Feb 2017 8:22pm |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 726 |
Hello,
Im.thinking of getting that dinitrol 3125, does it have to be sprayed with a gun, or is there a trigger on.the top!! I have surface rust on the rear cross member, hopefully this will stop it, and then will get some black paint!!!! |
27th Feb 2017 8:27pm |
You can get it in aerosol and with internal staws etc.on the Rejel site or via eBay. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
27th Feb 2017 8:37pm |
Cool thanks
This forum is great, so many helpfull people! |
27th Feb 2017 8:44pm |
There is standard straws and there are internal tubing ones that are long with a 90 degree angle spray pattern that sprays 108 degrees as you draw it back through internal components. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
27th Feb 2017 9:20pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 247 |
I used this. Looks factory fresh and hard wearing -
http://www.frost.co.uk/brands/eastwood/eas...-397g.html 1953 80" 1987 mini city e 2011 90" |
27th Feb 2017 10:33pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
I sanded down the crossmember removing as much old paint / rust as possible. Used DP90 2 part epoxy primer, then topcoat of Trim Black.
So far, it's held up well. I have no doubt it won't be the last time I have to do it. Once you have rust, it's never going away It's just a matter of how much you can slow it down Click image to enlarge Click image to enlarge it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
27th Feb 2017 11:17pm |
re. the dinitrol, you can get it in a Shultz can and use a gun or it's available in aerosol cans with extension wands available for them. I think i used the gun on this, but the aerosols would do it too, they;re also good for when you need more control, like spraying it into a narrow crack.
TBH while i used Upol satin, any old satin black will match the factory finish, it's the prep work you do underneath that makes the difference. |
28th Feb 2017 12:46am |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
OK I have my Buzzweld kit of primer and satin, here are some pics of the member, how much prep work do i need to do on it, is it just a bit of sanding to get rid of the pitting, ie I don't need to get it back to silver with no paint on it?
Its 2008 not a P by the way Thanks JD Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2008 TDCi 2.4 XS CSW |
30th Apr 2017 12:17pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1204 |
According to the Buzzweld website you don't need to take it back to bare metal. However, if you have the time why not. No rust then... Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
30th Apr 2017 1:25pm |
