![]() | Home > Maintenance & Modifications > Simple job |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
A note on what I've found in the difrences of the 3 types in the photo. (For some it's a sucking eggs moment but for others it may help) Left is the cap for the locking nut, its got a concave dimple. There should be a plastic removal tool in the kit with the wheel brace, jack handles and lock nut adaptor. There is times when the adaptor strips/pins bend making it hard to use, particularly if used with a rattle gun. We don't have the theft problems over here so I've replaced mine with standard nuts. I'm not getting caught out 200 miles from help with a stuck locking nut. Middle is the standard wheel nut, a clean dome finish. Sometimes you will feel some movement, its normal and is not a cap. Use a 27mm socket as mentioned. Right is the spare wheel nut, it's got a convex dimple. As with the standard nut it's not a cover even though it may have a little movement. Use the 27mm socket to remove. The thread in this nut allows for fitting over the longer studs on the spare wheel carrier. Cheers, Kyle. |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Thanks kyle
![]() 2008 SVX 90 2000 XS TD5 90 |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
Kyle - for some reason I can't see your pics.
The next time I can have a play with this problem is Tuesday so watch this space. Thanks for all your help so far. Guy May your life be like toilet paper ; long & useful. |
I was cheating and used Suliuli's photo which is why I copied his post ![]() Kyle. |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
Maybe stating the obvious but have you tried the black cap remover that is supplied in the tool kit - the locking wheel nut adapter is normally held in it. Push/ tap it on until it clicks it on and it clipped over the wheel nut cover, pull it off and it pulls off the cover.
Cheers Darren Darren |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
And if you do put the cap remover over a normal nut it will get stuck, but you can fit the wheel brace inside it to remove the nut, complete with cap remover.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
The other two nuts will be standard alloy nuts. The caps won't come off. 27mm socket can be tight but is the correct size and will fit over the finishing caps ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
![]() ![]() So I revisited the problem yesterday & you chaps are right & I am wrong ![]() ![]() ![]() My nuts are now loose. Still need to find something way more user friendly & black for my Bowlers. Thanks for everyones input Guy May your life be like toilet paper ; long & useful. |
There are black versions of the standard nuts available.
http://www.ebay.co.uk/itm/Set-of-20-X-27mm...3641.l6368 I've no experience of how well the black finish lasts mind you. |
Those ones from Mudstuff only fit M6, M8 and M10 nuts, so they're somewhat small for 27mm wheel nuts.
I have just fitted the ones from LRI last weekend, they are painted not anodised so need to be mindful, i removed old silver ones with with impact wrench but fitted black ones with socket and long bar then torque wrench and no paint damage. If you want black anodised then I found a company but they will cost nearly 300 including locking nuts
![]() Click image to enlarge 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 242 ![]() ![]() ![]() |
Found this today and checked my wheel nuts. Found 2 of the raised dimple spare wheel nuts on the wheels and swapped them with the smooth head nuts that were incorrectly on the spare wheel. As a bonus the annoying rattle when closing the back door has now been solved. ![]() “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
