Home > My Defender > Grafty's Td5 90
Page 18 of 124 <123 ... 171819 ... 122123124>
Procta
Looking good grafty, Where did you get those seats from? Mine have seen better days have they not. So I am looking at a possible change over.
Also what do your old seats look like? I am sort of toying with the idea of going bucket, or staying with the land rover seats. But I do motorway miles so I need a little bit of lux. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #602477 17th Feb 2017 1:36am
grafty99
The seats came from IRB developments - another customer had ordered them and had a change of heart so I bought them Mr. Green
My current seats are standard XS Td5 seats which are the same shape as Tdi ones. This gives you an idea of what they look like (crappy image from google)
As standard the xs seats are heated - which is nice. I use mine quite a bit.
I find them really comfortable and have no problem driving without stopping until I need fuel Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #602516 17th Feb 2017 9:50am
Procta
They nice, what are you after for yours? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #602589 17th Feb 2017 2:46pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
grafty99 wrote:
Just to note that by putting the speedo healer before the ecu but after the speedometer - the displayed speed remains unchanged - only the ecu speed is changed.
The defender is wired
Speed transducer (transfer box)
V
Speedometer in dash binnacle (speed pulse doubled for ecu to read)
V
ECU receives pulse for cruise control etc
Thumbs Up
Perfect thanks Grafty, speedo healer on order Thumbs Up
Ref Bogwert's query about cruise control switches, I'm planning to use a D2 switch and mount in on the column besides the wiper stalk. Should be a bit tidier than the loose switches i have hanging out below the clock currently Embarassed
Post #602604 17th Feb 2017 4:13pm
grafty99
No problem, I have seen D2 switches mounted on the column before, it looks smart Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602626 17th Feb 2017 6:06pm
grafty99
Just for clarity
V
V Speedo healer here Exclamation
1990 Vogue SE
Post #602627 17th Feb 2017 6:08pm
grafty99
Procta PM inbound Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602629 17th Feb 2017 6:11pm
grafty99
Harry.O picture of D2 switches on a defender column Thumbs Up (picture courtesy of google)
1990 Vogue SE
Post #602630 17th Feb 2017 6:13pm
L110CDL
Thanks for the the mug of tea grafty99 Thumbs Up Great to see you "both" in the flesh, had a great time Cool Clayton.
Keeper.
Post #602886 18th Feb 2017 9:43pm
grafty99
No problem! Thanks for popping by, nice to put a face to the name Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602919 18th Feb 2017 11:31pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
So if I buy a d2 cruise on/off switch and the set/res what do I need to do to make it all work?
Thanks in advance 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #602925 18th Feb 2017 11:56pm
grafty99
To make it work with standard gearing all you need is;
The control switches and some basic wiring from 12v then to the switches then on to the ecu.
I know this works from 2002 onwards Td5s but not sure about pre 2002.
If you have taller gearing (discovery transfer box etc) then all of the above applies except you also need a speedo healer to interrupt the speed signal going into the ecu.
This allows the ecu to see a slower speed that is actually occurring and so it stays within it's rpm vs speed parameters which it will go outside of with taller gearing.
Hopefully this helps Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602926 19th Feb 2017 12:13am
pj2106
Grafts that's great std box and have the 2 switches on the way 👍 It is a2003 so should be good 2008 110 2.4 XS Utility (Hagrid)
Post #602962 19th Feb 2017 9:20am
Stiff1
Can this be utilized with the Puma?
Post #603038 19th Feb 2017 3:55pm
grafty99
Ideal pj2106 yeah will work on a 2003
Stiff1 Unfortunately it won't work on a puma. You'll need a separate cruise control unit from the likes of mobilecentre Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #603051 19th Feb 2017 4:30pm
