Home > My Defender > Grafty's Td5 90
Page 17 of 124 <123 ... 161718 ... 122123124>
grafty99
I have been gradually upgrading the mechanicals of mine over the last few years so I'm on top of that now. The XS seats are very nice, especially the premium option. The support is excellent and heating function is great. Thumbs Up
Having said that the standard Td5 XS seats I find very comfortable and have done 600+ mile days in them no problem at all. The premium puma option is just another step up Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #601892 14th Feb 2017 10:03pm
L110CDL
They look nice and comfortable, cant beat it on those longer journeys Thumbs Up Clayton.
Keeper.
Post #602143 15th Feb 2017 11:01pm
grafty99
Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602151 15th Feb 2017 11:12pm
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Wicked thread! The 90 looks awesome. Thumbs Up
After skim reading some of the thread, did you say you had Cruse Control on it?
How easy was that to fit? It is just an additional stem on the steering column? Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #602213 16th Feb 2017 11:42am
grafty99
Thank you bogwert Bow down
I do have cruise control, all Td5s have it from the factory you just have to run wires from wherever you put the switches to the ecu.
Because I have a puma transfer box and taller 5th gear I had to put a speedo healer in between the speedo and ecu so it would work on the taller gearing.
Overall cost with the speedo healer is probably around £100
Works flawlessly and I use it a lot Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602240 16th Feb 2017 1:50pm
Green Machine
Which CC control switches / unit did you use Grafty? The Mobile Centre one? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #602250 16th Feb 2017 2:16pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Hi Grafty, I've recently fitted a recon box with a v8 5th gear ratio and it's killed my cruise control also. Which wires did you connect the speedo healer into? Did it actually adjust the speedo reading or just alter the pulses to the ECU which allow cruise control? Cracking Defender also mate Thumbs Up
Post #602306 16th Feb 2017 5:12pm
grafty99
Green Machine - there is no unit required as it is built into the Td5 ecu as a left over from the Td5 discovery Thumbs Up I used carling switches for the cruise control. A simple "on-off" one for cruise isolation. And a "momentary-off-momentary" switch for set/accelerate and cancel/resume.
These were wired in using this diagram. The ecu pins are econoseal female pins.
I have my carling switches to the right of the steering column where the 3 switches are on a Tdi.
If you have standard gearing then the cruise will work with the simple wiring above.
I had to add a speedo healer to mine as I have taller gearing which leads me onto
Harry.O - yes any deviation from the standard gearing will stop the cruise control working in 5th gear as the ecu thinks the vehicle is traveling too fast relative to engine speed. This puts the cruise control out of parameters and it won't activate.
To cure this, as mentioned, I fitted a speedo healer (from flatdog). The speedo healer interrupts the pulse sent from the speedo in the dash to the ecu. I put mine under the drivers seat next to the ecu.
There is ignition live and earth under there which makes this location ideal.
You remove pin 13 black plug (I did this and made an extension loom to avoid cutting) this is the signal wire.
Then just setup the speedo healer to slow down the speed seen by the ecu. I reduced mine by 19% and it worked first time Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602323 16th Feb 2017 6:44pm
grafty99
Just to note that by putting the speedo healer before the ecu but after the speedometer - the displayed speed remains unchanged - only the ecu speed is changed.
The defender is wired
Speed transducer (transfer box)
V
Speedometer in dash binnacle (speed pulse doubled for ecu to read)
V
ECU receives pulse for cruise control etc
1990 Vogue SE
Post #602324 16th Feb 2017 6:51pm
grafty99
I've had man flu all week so to perk myself up I bought some aero wiper blades for my 90. They will replace the cheap wipac ones which have lasted around 2 months Laughing
Think they look quite smart Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602367 16th Feb 2017 8:23pm
L110CDL
They do look nice there Thumbs Up I have fitted Bosch Aero's on mine as recommended on this forum and is one of the best mods you can do, they are 100 times better than the originals Mr. Green Clayton.
Keeper.
Post #602399 16th Feb 2017 9:47pm
grafty99
Cheers Clayton Thumbs Up these are bosch ones. Delivered to my door by Pat Williams as I couldn't face going into Barnstaple Laughing
When I'm feeling better I'll go for a drive and test them out Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602407 16th Feb 2017 9:53pm
L110CDL
You wont regret it, they are soooooooo good, got mine of ebay Thumbs Up you should of said i could off popped them out to you as im in Braunton working at the moment Thumbs Up Clayton.
Keeper.
Post #602429 16th Feb 2017 10:43pm
grafty99
Ahh bummer, thanks for the offer Thumbs Up
I have an account at Pat Williams so delivery is free Very Happy
Pop in tomorrow if you're feel like it, I'll be around all day. I'll PM you my mobile number Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602432 16th Feb 2017 10:47pm
L110CDL
Thumbs Up Thumbs Up Clayton.
Keeper.
Post #602447 16th Feb 2017 11:17pm
