Home > Off Topic > Towing rules
mse
Towing rules
Just needed to vent...why to towing rules follow no logical sense and no one care to make them more logical (and to some extent fair)
Oh and why do they change the rules, so slightly it makes it harder to check anything Mike
Post #601361 12th Feb 2017 11:24pm
X4SKP
Hello mse
Do you mean...
getting your 'full' licence parts B and E
knowing if you need a type approved towing frame
knowing your MRO (Mass Running Order)
knowing your MAM (Maximum Authorised Mass)
knowing your MPW (Maximum Permissible Weight)
knowing your GVW (Gross Vehicle Weight)
knowing your MTPLM (Maximum Technically Permitted Laden Mass)
knowing you MPTW (Maximum Permissible Towing Mass)
knowing what restrictions you have if your Trailer is Unbraked
knowing the width rule changes in the UK (2010)
knowing the towing speeds across Europe
knowing the speed signs to be displayed in Europe
knowing the rear lighting requirements in Europe
or what rear view mirrors to fit... Question SKIP
Post #601373 13th Feb 2017 1:09am
miker
Before I went and passed my B+E, I could tow a heavier trailer behind my Seat ibiza than behind my defender....
Any questions?!
Post #601376 13th Feb 2017 1:31am
mse
No I have my B+E and C and D1 - its the silly rules around C and all the combinations of trailers and how things arent thought through and then grandfather rights.
So crazy example, i can tow a plated C1 vehicle behind the defender...but i cant tow the defender behind the same C1 vehicle!
There are many other madnesses, but thats the one that im ranting at!!!
Ignoring towing speeds but the 3050 UK unladen limit v the european 3.5t limit meaning in the UK some vehicles can drive faster than they can in Europe. Mike
Post #601498 13th Feb 2017 5:50pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Thumbs Up for Grandfather rights. Mind you I did start towing and driving H.G.V. artic units around a certain I.C.I. site at 17.
Thank God I don't have to deal with offences connected with towing anymore , gone are the days of towing anything as long as it was safe. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #601589 13th Feb 2017 10:01pm
mse
Its got a little ridiculous - there isnt any logic to it either
Like the example above 7t is different to 7t - where one is less safe than the other, apparently. But then its ok for grandfather rights people to go to 8.25t, but not 12.
I appreciate you need to draw the line somewhere...but the line could be consistent and clear but meaning different things
Eg in the example above the +E could give 3.5t towing on all categories etc etc
At the minute there are people with different types of +E entitlement - if i did my +E tomorrow, i found out i would be limited to (from memory) 3.5t and a 7 ton combination - but older +E's dont have that restriction - so you could couple the brakes and go higher
Back to my c example 750kg on a car i get...but 750kg on a rigid is nothing and not sensible Mike
Post #601604 13th Feb 2017 10:14pm
