![]() | Home > In Car Electronics > Blakview Mounting Location |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
I don't have a rear view mirror (can't see anything out of it with dark tints on the rear anyway) so its top centre of screen at the front and top of the rear door by the hinge - easy for wiring - with a little window cut in the tint
I used to have the display on rear view full time - but as the image is not mirror image so I found it very odd. Good luck Keith |
Busboy Member Since: 23 Jan 2012 Location: West London Posts: 182 ![]() ![]() ![]() |
Thanks keith
with all the road sh**e thrown up at my screen recently i was thinking of an offset position to keep it in the clean area of the windscreen... Steve |
flydive Member Since: 27 Aug 2015 Location: Lugano Posts: 290 ![]() ![]() ![]() |
Not Blackvue, but probably close enough.
Front. Probably mounting it slightly lower would help a bit with GPS reception(but it might be just a Thinkware problem) ![]() Click image to enlarge Rear. Left window. Easier to run the wire than on the door. Also in the centre window you have the brake light. ![]() Click image to enlarge |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Not a Blackvue but I have mine behind the rear view mirror in the wiped area of the screen so the video remains clear in the rain
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Both front and rear are within the swept area of the windows.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17868 ![]() ![]() ![]() |
Front - behind the place where once there was a rear view mirror (now technically illegal since it obscures more than 40mm of the swept area, but it didn't when the mirror was fitted, and no-one's ever picked it up at MOT time).
Rear - attached to the swing-away wheel carrier below the wheel, since all other locations simply filmed the spare wheel and not much else. |
