Home > In Car Electronics > Blakview Mounting Location
Busboy
I'M looking at installing the Blackview 2 channel dashcam setup and was looking to see where you guys have mounted yours.... (and i know that one goes front and one to the rear Very Happy Very Happy Very Happy Very Happy) just want some ideas to fine tune the mounting positions
regards Steve Steve
Post #601202 12th Feb 2017 5:27pm
ickle
I don't have a rear view mirror (can't see anything out of it with dark tints on the rear anyway) so its top centre of screen at the front and top of the rear door by the hinge - easy for wiring - with a little window cut in the tint
I used to have the display on rear view full time - but as the image is not mirror image so I found it very odd.
Good luck
Keith
Post #601208 12th Feb 2017 5:41pm
Busboy
Thanks keith
with all the road sh**e thrown up at my screen recently i was thinking of an offset position to keep it in the clean area of the windscreen... Steve
Post #601218 12th Feb 2017 6:05pm
flydive
Switzerland 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Not Blackvue, but probably close enough.
Front. Probably mounting it slightly lower would help a bit with GPS reception(but it might be just a Thinkware problem)
Rear. Left window. Easier to run the wire than on the door. Also in the centre window you have the brake light.
Post #601227 12th Feb 2017 6:29pm
grafty99
Not a Blackvue but I have mine behind the rear view mirror in the wiped area of the screen so the video remains clear in the rain Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #601232 12th Feb 2017 6:49pm
ickle
Both front and rear are within the swept area of the windows. Thumbs Up
Post #601275 12th Feb 2017 8:21pm
Front - behind the place where once there was a rear view mirror (now technically illegal since it obscures more than 40mm of the swept area, but it didn't when the mirror was fitted, and no-one's ever picked it up at MOT time).
Rear - attached to the swing-away wheel carrier below the wheel, since all other locations simply filmed the spare wheel and not much else.
Post #601347 12th Feb 2017 10:35pm
