Home > Puma (Tdci) > EGR Blanking Plate
OldDD
Isle Of Man 2012 Defender 90 Puma 2.2 HT Orkney Grey
EGR Blanking Plate
Despite the fact it is now possible to disable EGR in Software, does it still make sense to use a blanking plate to block off the EGR mechanically? Belt and braces like Smile??
Post #600899 11th Feb 2017 10:50am
It is a good idea yes. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #600915 11th Feb 2017 12:04pm
OldDD
Any idea where I can get one from??
Post #600925 11th Feb 2017 1:05pm
Alive tuning. Or BAS.
I have the former but they are available elsewhere. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #600926 11th Feb 2017 1:15pm
Just had a chat with Gary the owner of Alive tuning.
He says it is always recommended to be fitted for certain.
I think they have some on the site, they slip in between the two EGR mating faces then you retighten.
Torque figures for the bolts are in my 'gallery' WSM.
http://www.alivetuning.com/contact/ _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #600940 11th Feb 2017 2:05pm
Rickydodah
http://www.ebay.co.uk/itm/EGR-blanking-pla...xylpNTUkOV
They also do versions for the 2.2 if that's what you need Thumbs Up I started with nothing and still have most of it left!
Post #600942 11th Feb 2017 2:18pm
OldDD
Thanks Guys
I'm slowly working through the list of improvements I want to make to this truck and the EGR block off is high on the list as I've had great results doing this with other cars.
DPF /CAT delete next Smile!!
Post #601006 11th Feb 2017 8:08pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
So if you fit the egr blanking plate what happens when you reload the standard factory tune map? Surely the standard map requires the egr to cycle and if not does this throw out engine fault codes?
Post #601007 11th Feb 2017 8:17pm
OldDD
It probably does but I have absolutely no intentions of ever going back to the standard map. It's pants!!!
Post #601009 11th Feb 2017 8:29pm
Froglaise
You get a light on the dash and a quieter engine with a bit better performance at times (possibly imaginary).
I have an Alive map and egr blanking and have gone back to the standard map but the plate is staying in.
Post #601010 11th Feb 2017 8:31pm
Scoobeenut
I always reload the standard map when I put it in for service or maintenance as I don't want the garage to overwrite anything onto the tuned map.
Post #601014 11th Feb 2017 8:45pm
^^^^ Same here. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #601018 11th Feb 2017 8:50pm
OldDD
Mine is a Twisted so they know it's tuned and never plug in / rewrite.
Post #601020 11th Feb 2017 8:57pm
mk1collector
I presume this is not the td5 in your sig Ray
My build thread
Post #601028 11th Feb 2017 9:09pm
OldDD
Haha!!
No, I'll have to change that - Sold Darth last year and picked up a very nice Twisted 90 TDCI to replace it.
Post #601031 11th Feb 2017 9:15pm
