![]() | Home > Puma (Tdci) > EGR Blanking Plate |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
It is a good idea yes.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
OldDD Member Since: 17 Jan 2016 Location: Ballaugh Posts: 54 ![]() ![]() ![]() |
Any idea where I can get one from??
Alive tuning. Or BAS.
I have the former but they are available elsewhere. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Just had a chat with Gary the owner of Alive tuning.
He says it is always recommended to be fitted for certain. I think they have some on the site, they slip in between the two EGR mating faces then you retighten. Torque figures for the bolts are in my 'gallery' WSM. http://www.alivetuning.com/contact/ ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
http://www.ebay.co.uk/itm/EGR-blanking-pla...xylpNTUkOV They also do versions for the 2.2 if that's what you need ![]() |
Thanks Guys
I'm slowly working through the list of improvements I want to make to this truck and the EGR block off is high on the list as I've had great results doing this with other cars. DPF /CAT delete next ![]() |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
So if you fit the egr blanking plate what happens when you reload the standard factory tune map? Surely the standard map requires the egr to cycle and if not does this throw out engine fault codes?
It probably does but I have absolutely no intentions of ever going back to the standard map. It's pants!!!
Froglaise Member Since: 24 Sep 2016 Location: left forum Posts: 212 ![]() |
You get a light on the dash and a quieter engine with a bit better performance at times (possibly imaginary). I have an Alive map and egr blanking and have gone back to the standard map but the plate is staying in. |
I always reload the standard map when I put it in for service or maintenance as I don't want the garage to overwrite anything onto the tuned map.
^^^^ Same here. ____\We|Will|Win/___
Mine is a Twisted so they know it's tuned and never plug in / rewrite.
I presume this is not the td5 in your sig Ray
Haha!!
No, I'll have to change that - Sold Darth last year and picked up a very nice Twisted 90 TDCI to replace it. |
