Home > Td5 > Can it be done? Bezel Louvre side air vents on a TD5
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Its the time of year again when driving anywhere the side windows mist up and you can see ... nowt! Arguably in Scotland that time is between Late August and early June. Confused
My idea is (without spending £100+ on vents) to fit Bezel Louvre vents off a Puma to the sides?
Surely someone has tried this...?
My thoughts are, take off the dash, fit in a bit of conduit pipe to the main windscreen blowers, divert it along to the side, drill a... probably square hole, and attached a Bezel vent?
Can it be done? or why can't it be done? Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #600362 9th Feb 2017 2:30pm
geobloke
I have not seen those vents being used, but I do remember someone DIYing vents with bulkhead fixings and ducting...
Probably on here...
Post #600378 9th Feb 2017 3:56pm
geobloke
This is Retroannocondas take on the mod
http://www.retroanaconda.com/landrover/201...demisters/
But it is not the one I remember.
Post #600379 9th Feb 2017 3:58pm
geobloke
Another version from this forum;
http://www.defender2.net/forum/topic33126.html
But still not the one I remember
Post #600380 9th Feb 2017 4:01pm
bankz5152
I'm planning to do the exact same thing using the above vents, I cant imagine it will be too difficult.
Post #600381 9th Feb 2017 4:08pm
bogwert
Ok, these are similar to what I had in mind.
But can you use the side air vents off a puma?
Anyone happen to know the dimensions of one? See if it will fit the side. Chris
Post #600396 9th Feb 2017 5:23pm
grafty99
Could work, it just depends on the dimensions of the puma vents 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #600401 9th Feb 2017 5:57pm
rallysteve
think you will find you will be very limited by using those vents. The heater controls at the driver's end don't leave much room for a duct/vent to pass through.
Passenger side the rubber handle only has a small area too.
The defenderdemister kits have possibly the largest round vents you could easily fit with the convoluted tubing.
Post #600403 9th Feb 2017 6:15pm
bogwert
Cheers rallysteve.
Reading up on it, everyone seems to have used 15-20mm conduit.
Anyone know where i could find the dimensions to a puma vent? Chris
Post #600416 9th Feb 2017 7:20pm
grafty99
They're definately bigger than 20mm. More like 40 - 45mm Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #600417 9th Feb 2017 7:30pm
grafty99
But I don't know for sure, maybe someone with a puma could pop out with a tape Wink 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #600418 9th Feb 2017 7:32pm
bogwert
Nice one Grafty99!
Oh google is a wonderful thing.
Bezel Louvre's are 2cm x 8cm x 10cm Thumbs Up
Got a mate with a puma so i'll ask him to double check.
Time to get the paper and scissors out! Chris
Post #600419 9th Feb 2017 7:34pm
grafty99
Funnily enough this exact same mod went through my head a couple of days ago Laughing
I'm planning on implementing it slightly differently. I'm going to feed air into the top of the door card via a sealed duct. When the doors are shut air will pass into the door card and then escape between the top of the door card and glass which should hopefully demist the whole window.
I'm also planning a fan upgrade for more airflow Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #600422 9th Feb 2017 7:43pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
I can go out and measure if there is still a need?
Post #600440 9th Feb 2017 8:43pm
geobloke
Oooo what you thinking? Secondary inline fan motor or replace the existing one?
Post #600459 9th Feb 2017 9:29pm
