![]() | Home > Technical > 2015 TDCI Horn Connector |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
Derek - don't know if I am helpful here. Had an air horn installed - in the kit there was a switch - so that you could switch between normal horn and air horn. Auto electronics not my strong point - so I had a technician and fellow Defender club member install it.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20903 ![]() ![]() |
Photo would be useful.
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17838 ![]() ![]() ![]() |
I think that they are standard 2-pin Econoseal connectors.
DerekV Member Since: 12 Oct 2015 Location: Surrey Posts: 39 ![]() ![]() ![]() |
Thanks for your replies everyone!!
Here's a photo of the connector. Sorry it's not the greatest but it's pretty awkward to get at!! I've just noticed that there seems to be a number on the back - 985324-1 - and Googling it brings up an Italian eBay listing for a similar looking connector, so that may be it, but if so I'm not sure I'm going to be able to get hold of one in the UK. Assuming I'm not able to get one, does anyone know what size wire (mm2) is used for the horn, as I'll probably have to use a Posi-Tap connector but they're pretty specific with their sizing! Thanks. Derek. |
That's an AMP connector used inter alia on BMWs. Definitely not the Econoseal I thought it was sorry! Also (I think) used on Disco 2 horns.
Edit: update - just for the record, Disco2 horns and Defender horns have totally different connectors and are not directly interchangeable. Last edited by blackwolf on 25th Feb 2017 3:10pm. Edited 1 time in total |
Ah right, thanks blackwolf. Do you know where I could try to get one of those (and the male half) in the UK (Google turns up nothing), and also do you know if an econoseal crimper would work to crimp the terminals?
Also, do you know what wire size is used on the horn? Thanks. Derek. |
Offhand I'm afraid not, but I have a spare wing harness somewhere. If I can find it I might be able to figure out the wire size. It is unlikely that the crimps will be too specialised and I imagine an Econoseal type tool will do the job.
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
According to the electrical reference manual C003 and C004 are MQS series, LR part number YPC110600, wire is size 0.75 and terminals are LR part number YPL101510 if that is any use?
(doesn't directly help with the mating connector, but it might be a start) |
Thanks blackwolf and apt100! That's really useful info. Just need to find a mating connector now and I'll be sorted! If I can't find one I'll just use the posi tap now I know what the wire size is.
Thanks again for your help everyone! Derek. |
https://onedrive.live.com/?id=4BC2D89C85C7...9C85C7C171
BTW I got the documents from here if you are interested - helpfully posted by a member on previous threads ![]() |
Just a correction - the number written on the connector was actually 965324-1, not 985324-1!! I think I'll try writing to a shop that sells these connectors to see if they can suggest a mating one.
Derek. |
Ah wow, that's incredibly useful, I've been looking for a workshop manual for ages!! Thanks! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6680 ![]() ![]() ![]() |
I can supply a mating connector for these, drop me a PM
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Any Durite supplier should be able to get them, or Paul at LRconnectors is an absolute gent and a legend for this stuff.
