![]() | Home > Wheels & Tyres > bitumen paint on tyres |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello stricko
Have you tried cleaning the Tyre with Diesel... ![]() https://www.defender2.net/forum/topic83242.html |
stricko Member Since: 30 Nov 2015 Location: East Sussex Posts: 120 ![]() ![]() |
I haven't. I will try and do that at the weekend. ---------------------------------------------------------------
Orangesofa Member Since: 10 Oct 2014 Location: Somerset Posts: 214 ![]() ![]() ![]() |
I would be sure to remove all trace of diesel off your tyre if you do use it
![]() The tiniest amount of spilt diesel on the road turns the surface into an ice-rink and takes the lives of many motorcyclists each year the world over. Cleaning a tyre with the stuff should be a last resort. White spirit could be a consideration but long term affects of using any form of solvent on your tyre could be something to think about and it may be a slip hazard too. Perhaps use anything sparingly and give the tyre a very good clean to remove any solvent/fuel residue as soon possible afterwards. Phil |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Why not go and drive a few lanes?
That will sort out your problem ![]() Wanted, Forward Control Anything considered. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Would deflating the tyre ( to 10psi for example) and then moving the vehicle forwards and backwards through one wheel revolution help flex the paint off? 2002 90 Td5 Station Wagon
