![]() | Home > Td5 > Leather steering wheel |
Your best taking your wheel off and counting the splines in the middle. My td5 is 36 spline and most if not all pumas are 48 spline but apparently Landrover could have put either size in randomly from what I've read. Ray
Will osborne Member Since: 12 Jan 2017 Location: West midlands Posts: 14 ![]() ![]() ![]() |
Im pretty sure it is 48, so if it is it will fit fine?
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Apart from 2015 onwards model year as they had a steering angle sensor so won't fit. Anything with the same number of splines up to 2015 will be fine though
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6703 ![]() ![]() ![]() |
I've updated this with details of the DSC wheels:
http://web-rover.co.uk/articles-steeringwheels.html ![]() ![]() |
Ok thanks
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Have a 2016 puma steering wheel on my 02 td5.
You need a little mod to that to tack on the turn cancel "knuckles" and it will work great. Alternative you can manually flick the indicator back. The defender has migrated, leaving the owner behind. |
Do you just make up some tabs the same as on the original wheel and weld them on the MY2015+ steering wheel?
Or you do see like a track where you can fit in a small bolt, both top and bottom, that will also allow for that to push the blue ring on the turn cancel.
Squeeze one in and tack weld it and you are good to go. The defender has migrated, leaving the owner behind. |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Looks like your well on the way Will osborne to sorting this out...
but for others wanting to know where they are starting from... ![]() Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
Yes it can be either - my '07MY Puma is 36 spline. Definitely worth checking. |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
I`ve got one..lovely
L90DNY Member Since: 09 Feb 2016 Location: Somerset Posts: 117 ![]() ![]() ![]() |
I've got one on my 05 Td5 90, it was a 2012 48 spline, good year to get as you can still use your indicators
I've updated it since your screen shot ![]() ![]() ![]() |
