![]() | Home > Technical > Diagnostic reader for 300 TDi 90 |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
I'd be highly surprised if ANY diagnostic kit worked on a 300TDi
![]() In all seriousness, there will be something to connect to the alarm module for coding key fobs etc, but that's about it |
Roosterrs Member Since: 19 Feb 2016 Location: Northants Posts: 48 ![]() ![]() |
Ok no worries, just trying to see if the alarm module was causing an issue on my vehicle. Scrolling through the menus it says 1997 10th letter of VIN =V but only showers discovery, freelander and range rover. Scrolling through a couple of menus does show defender and states where the connection is, but won't read. Thanks for your help.
The only two thing 1997 300 TDI EGR control unit and 10AS alarm unit
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5354 ![]() ![]() |
where is the Diagnostic port on the 300? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
thompjas Member Since: 07 Mar 2014 Location: Northants Posts: 36 ![]() ![]() |
The port is at the front of the middle seat / cubby box area and close to the passenger seat if that makes sense !
Tia4 Member Since: 15 May 2012 Location: Surrey Posts: 48 ![]() ![]() ![]() |
I have these ports under my middle seat always wondered what they were for. I see they are diagnostic ports but what would they check for? It's a 300 tdi
EGR control unit programming and 10AS alarm unit programming it more a programming port as no ECU is fitted to 300 tdi late model
