![]() | Home > Technical > Diagnostic reader for 300 TDi 90 |
| Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532
I'd be highly surprised if ANY diagnostic kit worked on a 300TDi
In all seriousness, there will be something to connect to the alarm module for coding key fobs etc, but that's about it |
| Roosterrs Member Since: 19 Feb 2016 Location: Northants Posts: 48
Ok no worries, just trying to see if the alarm module was causing an issue on my vehicle. Scrolling through the menus it says 1997 10th letter of VIN =V but only showers discovery, freelander and range rover. Scrolling through a couple of menus does show defender and states where the connection is, but won't read. Thanks for your help.
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
The only two thing 1997 300 TDI EGR control unit and 10AS alarm unit
| Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5374
where is the Diagnostic port on the 300? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Click image to enlarge |
| thompjas Member Since: 07 Mar 2014 Location: Northants Posts: 36
The port is at the front of the middle seat / cubby box area and close to the passenger seat if that makes sense !
| Tia4 Member Since: 15 May 2012 Location: Surrey Posts: 48
I have these ports under my middle seat always wondered what they were for. I see they are diagnostic ports but what would they check for? It's a 300 tdi
EGR control unit programming and 10AS alarm unit programming it more a programming port as no ECU is fitted to 300 tdi late model
