Home > Maintenance & Modifications > Steering wheel
Page 2 of 4 <1234>
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
If you have the roll pins sticking out of the bottom of the boss, it should still cancel the indicators. What may have happened is that the blue plastic ring on the indicator assembly that cancels the indicators is 180� out. I'm sure there is a wee tab on one side of the blue bit and this needs to point to the right hand side. Worth a look.
Post #596125 25th Jan 2017 12:22pm
smb
leeds wrote:
We might also have something else up our sleeves Whistle Whistle
Brendan
Come on Brendan, let it out the bag. I really need to sort my steering wheel out in the next 2 weeks. Was about to push the button and you have gone and bu..er'd it up. How long have we got to wait? Does it include Quick Release?
Kindest regards, but Very pi..ed off,
Steve
Post #596132 25th Jan 2017 12:37pm
DAZ110
Hello JOW240725, (James)
Maybe the roll pins aren't quite long enough to fit far enough into the self cancelling slots in the blue plastic ring?
The roll pins might need pulling out of the back of the steering wheel a bit further or extending in some way?
Post #596135 25th Jan 2017 12:42pm
JOW240725
Thanks all, I'll just wait for X4SKP post then I'll tackle it again with all the ideas Thumbs Up James
Instagram @suffolk_rovers
Post #596281 25th Jan 2017 10:45pm
X4SKP
Hello JOW240725
DAZ110 is right...well that was my problem, The Self Cancelling Pins on the Boss were not long enough
and really not wide enough to reach and engage nicely within the Blue Plastic Collar on the Steering Column.
So I made a replacement set which push fitted over the Standard Pins projecting from the Boss.
The standard Boss Pins (on this Boss) are Split Pins so with a tight fit the new 'Over Pins'
could be tapped into position.
A Picture is worth a thousand words...
The Original Boss had two slightly longer pins on each side engaging with the Boss...which worked well
although I noticed that they too only just engaged, but 'picked up' the Collar well and did the job.
The Blue Collar
The Boss with the Single Pins which did not now reach...just, and were slower to pick up and rotate /
cancel the Indicators, my 'work around' Pins waiting for adding in are along side
Longer Fatter Pins fixed to Boss
This Boss now engages as it should
End Result OK, but in truth the two wider Spaced Pins (on each side of the original) were better,
on a slow corner, requiring not much steering the action is too late in cancelling,
I can fix this but it needs a MK II version of the Pins...so this has fallen down the TO DO List
Have a Look at yours, if you think it's the same issue try to source some pins to engage with the
Blue Collar, this may do the trick.
Edit update...
MK II version of the Pins turned into just adding two 10mm dia Nylon Sleeves over the Pins
and flattening these slightly to fit over the Steering Column, they engage with the Blue Collar
now perfectly, with 1mm total clearance, so the 'pick up' is quicker, self cancel is now as it should be
Good Luck... SKIP
Post #596291 25th Jan 2017 10:58pm
JOW240725
Brilliant!! Thank you all. Looking at those photos, I'm sure I don't have pins at all so no wonder it isn't working! Job for the weekend, thank you! Thumbs Up James
Post #596344 26th Jan 2017 10:02am
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I like the thought of a removeable steering wheel, however, does the combination of an aftermarket wheel and a snap off boss bring the steering wheel closer to the driver and is there a combination that doesn't?
Regards
Phil 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #596349 26th Jan 2017 10:24am
JOW240725
The quick release boss I have is the same depth as the standard Startech boss. Photo's stolen from a previous thread.
 James
Post #596358 26th Jan 2017 11:18am
Froglaise
Do you happen know which quick release boss that is...i..e one that fits the Startech and is same width as their boss?
Post #596361 26th Jan 2017 11:27am
JOW240725
It was originally supplied by FCX but sadly no longer available from them. I do have the boxes at home so will check and confirm later.
Optimill do a nice slimline quick release boss but don't know if it fits a Startech http://optimillraceproducts.com/product_in...ucts_id=93 James
Post #596366 26th Jan 2017 11:43am
DAZ110
Might be this one?:
http://www.ebay.co.uk/itm/RDX-SLIMLINE-Ste...1290273131
Post #596462 26th Jan 2017 6:24pm
Froglaise
Thx.
From the research I've done it seems the Startech is manufactured by Raid so assuming then the boss is one that fits Raid spacing.
Post #596467 26th Jan 2017 6:32pm
JOW240725
Optimill quick release is very slim line, see thread http://www.defender2.net/forum/topic37616-15.html It is for Momo but not sure if this is different to Startech?
I'll check the make when I get home. James
Post #596476 26th Jan 2017 6:44pm
X4SKP
300TDi CSW Phil wrote:
I like the thought of a removeable steering wheel, however, does the combination of an aftermarket wheel and a snap off boss bring the steering wheel closer to the driver and is there a combination that doesn't? Regards Phil
Startech + 'Standard Boss' Dimensions shown below, when I added the FXC Boss + Snap Off (combination) this positioned the Wheel slightly nearer the driver but we are talking mm. All Controls with this set up are effectively as before.
Snap Off thickness is 27.6mm + your Boss Thickness will set up the stand off position of the back face of your chosen wheel
 SKIP
Post #596509 26th Jan 2017 8:51pm
X4SKP
One more Photo...with the 'extended' Pins engaged in the Blue Collar (Steering Column exposed)
 SKIP
Post #596771 27th Jan 2017 5:31pm
Page 2 of 4 <1234>
