![]() | Home > Maintenance & Modifications > Any way to increase heat output from TD5 heated seats? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I don't think there is I'm afraid. Unless you install another set of heating pads on top of the standard ones? 2002 90 Td5 Station Wagon
Hi Christian. Could it be that your 2006 seat heaters are getting a little old and ineffectual? The reason I say this is that I have recently fitted a set of heated Puma seats in to my TD5 and they get at times a little uncomfortably hot...!
I am happy to check the resistance of each element if you want to compare them. |
NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152 ![]() ![]() ![]() |
You probably need to change the heating pads. I've got a 2004 Td5 XS and mine get nice and warm. So much so that I find I have to turn them off after a while.
c_eilersen Member Since: 09 Oct 2016 Location: Copenhagen Posts: 11 ![]() ![]() ![]() |
Thank you for the replies.
The car is in really good condition - it was put away for storage btw 2006 and 2013 and only have 40.000 miles on it now, so I was hoping that the heater pads wasn't that worn.. But it looks I will take a look at the pads anyway. @Guy : It would be great if you could measure the resistance - (I am not an electrical engineer - where do I have to measure to compare? - across the pins on the seat plug?) If I am to change the pads - what part are the best to use? original LR parts or aftermarket like Exmoore? My LR originals only have one setting on/off - can I reuse the wiring for the Exmoore ones that have low/medium/high setting. Best, Christian |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1066 ![]() ![]() ![]() |
I had a problem with the heated seats in my Td5. Not factory fitted though.
One of the wires broke due to the constant twisting of the wire when I changed gear. Meant that only half the base was heated. |
I have to say the xs heated seats in my 2002 90 aren't amazing. They get warm and probably too warm after about an hour but then cool down again so can be pretty much on constantly - where as the ones in my parents L322 need to be turned off full power after about 5 minutes or they are uncomfortably warm.
There is definitely room for improvement. Especially in a soft top! 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
I have a set of XS factory "warmed" seats from 2015. I refer to them a "warmed" because they just don't get hot. From day 1 (and they only had a few hundred miles on them when I installed them) they have never measured up to my expectations as seat heaters. It's better than nothing, but there a TON of room for improvement. it's a Landrover thing...
my renovation thread: http://www.defender2.net/forum/topic40792.html |
K.M Member Since: 28 Apr 2016 Location: Salisbury Posts: 300 ![]() ![]() ![]() |
I completely agree! They take the chill off on a morning but other than that they're pretty useless! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20915 ![]() ![]() |
Swap over to Waeco pads and hardwire.(the low output feed only) ___\⭐️Lone|Star|State/___
____\We|Will|Win/___[/size] ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Would I be able to use the existing wirering and swithes in the dashboard with these?
Nakatanenga, today has announced new heater pads today. Unlike conventional heater pads these are carbon fibre ones, can be cut to size. If a single element fails it will continue to work unlike the more conventional ones.
I have not tried them or seen them yet. Nicking an English translation
Brendan |
This is the only solution in the winter. And yes it is an insulated one.
![]() Click image to enlarge ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
I read somewhere that you can change the temp cut of in the seat for a higher cut off, i'm not sure if it was someone in the states tho,
sorry for a vague response i just can't find it. Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
