Page 69 of 1392 <123 ... 686970 ... 139013911392>
TACK
BigRuss wrote:
TACK wrote:
Fitted a Mantec rear window Guard, just waiting for my new wheels Mr. Green
Tack how did you fit the guard? Did you rivet it in place?
Russell
russ it comes with 8 or so screws to fix it. it really did take 5 minutes Thumbs Up
Post #59325 16th Feb 2011 1:27am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
fitted some front HD springs ...
in this pic you can see a little diference ...
but in these you can see some diference ...
but I'm happy with the result ! Between winch (5o kg) and bumper (more 25 kg than standard) plus protections (+- 15 kg) plus all the bits I still want to add ... these will do ! And the 110 is now leveled ... for now ! Mr. Green Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #59429 16th Feb 2011 8:12pm
MK
The main difference I see are the snorkel and vent protection Whistle Puma 110" SW
Post #59489 17th Feb 2011 2:11am
BruceT
South Africa
MK the picture is reversed.....note the fuel filler also..... Very Happy
Post #59494 17th Feb 2011 5:56am
BigRuss
TACK wrote:
Russell
Thumbs Up Russell
2011MY 110 XS USW Black
Post #59501 17th Feb 2011 8:42am
Zagato
Bonnet stickers also gone or put on Wink
Question. If you have a snorkel fitted would the air intake on top of the wing not be sealed shut as well, or doesn't it matter?
Post #59504 17th Feb 2011 9:08am
AndrewS
The intake on the wing is for the air into the cab Thumbs Up 130's have feeling's as well you know Smile
Post #59524 17th Feb 2011 9:57am
lrmaniac
Nice eyes! Thumbs Up I fliped the pic on photoshop ... could not park the car in the same position !! Mr. Green But today I noticed some changes while driving ... especially when braking and passing through bumps ...! Very pleased with the changes ! Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #59534 17th Feb 2011 10:50am
MK
So you kept the OE shoxs. I bet you it does not feel a lot more stiff. The lift is about 1"? Puma 110" SW
Post #59537 17th Feb 2011 10:58am
lrmaniac
It's not a lift ... it's standard LR springs, but Heavy duty ones... NRC9448 and NRC9449, as I had the standard springs. It's now a lot more stiff, and the wheels tend to bounce less when I pass a bump ... As I usually don't carry any weight in the back I'll keep the standard ones there ... But the 110 is now leveled ... I'm happy with the changes! Mr. Green Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #59546 17th Feb 2011 11:33am
MK
So they are a bit shorter then? Puma 110" SW
Post #59551 17th Feb 2011 11:41am
lrmaniac
no...don't think so ... they're heavier ... but next to each other they're about the same height ... It's a diferent rate ...don't know much about springs, but it seems to me that the steel is thicker on the HD ones ... maybe that's why tey're havier ... Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #59555 17th Feb 2011 11:59am
TC
rear light guards
Managed to get the rear, very rusty, light guards off! What a Censored it was as well!
The guards have been on the truck since new and were looking in a right mess, powdercoat hanging off and rust showing through underneath. The self tappers had seized up nicely, got 5 out with sheer brute force (thought I was going to pop out a blood vessel or loose a struggling string) , one had to be drilled out (got to use my shiny new Makita combi) Shocked and the last one had to be almost knocked off with a chisel (couldn't get the drill directly at the screw head) Exclamation Shocked .
All is now nicely tidied up with a set of A4 stainless M5 bolts and washers. The back end looks transformed Very Happy
Great offer on the Makita BTW at Screwfix Thumbs Up
http://www.screwfix.com/prods/84044&cm...Y?ts=54525
Post #59619 17th Feb 2011 3:35pm
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
Fitted the overhead flip down DVD system with LEDs & wireless headphones & game controller - all for the kids
And then an in dash DVD / GPS / Hard Drive system for me!
[/img]
Now on to some bling from Entreq, and then the EGR kit from Alive.
It really does never end, this Landy obsession..... 2001 TD5 110 DCPU in Bonatti Grey
Post #60593 22nd Feb 2011 6:12pm
daviec1
EGR Kit from Alive now fitted. Will see if any noticeable difference in performance over next week or so.
Amazing what you find when doing this sort of thing. Am a complete mechanical novice - the last time I remember mucking around in an engine bay was alternator replacement in my old Volvo 340DL when I was 17.
It seems like a previous owner of my Landy had a new EGR fitted at some point. Hence removal of EGR from manifold to fit blanking plate was tricky, given that previous owner had already had to drill out old bolt & re-thread with larger size, plus fitting new bracket to engine.
Alive make a nice kit - simple & well made. Thumbs Up
Anyway, all out now, and put into the big pile of "used to be in the Landy" bits Laughing , in case it comes in handy in the future. 2001 TD5 110 DCPU in Bonatti Grey
Post #60915 24th Feb 2011 3:17pm
