![]() | Home > Maintenance & Modifications > Want new wheels/tyres..... |
hey bigee
you are right ... it has been asked before - do a search |
bigee Member Since: 24 Oct 2010 Location: middle of nowhere... Posts: 78 ![]() ![]() ![]() |
ta
![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
sorry i asked for some advice.
Just ignore the cranky old ![]() ![]() 265s fit perfectly well on the standard alloys and fill the arches a lot better. Height is about the same so no rubbing with standard suspension. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Thanks for that JSG....you have restored my faith in the forum
AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 793 ![]() ![]() |
JSG is right, a 265/75x16 fits just fine, but you may need to look at your lock stops.
![]() I have 265's fitted with 30mm spacers. Andy. |
![]() 265*75*16 on Anthracite zu's ![]() Bob |
Cheers guys,very helpful and always good to see pics
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8451 ![]() ![]() ![]() |
255.85s MT will go on to and be ok
or go big big 285 wise. an increase in height will change the gearing dont forget. i run 235.85 ATs and they work well for what i use the truck for. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
![]() ![]() Oh go on then!!! Hope Disco's not about! ![]() Mach 5s foreground Modulars rear! ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
(getting own back pedant mode..) i think you will find i'm a 'sensitive SOUL'
Fantastic looking Landy's though
Thank you! Mine and Fekete's taken at Tyneham in Dorset! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 16th Feb 2011 10:59pm. Edited 1 time in total |
