![]() | Home > Maintenance & Modifications > Want new wheels/tyres..... |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
hey bigee
you are right ... it has been asked before - do a search |
| bigee Member Since: 24 Oct 2010 Location: middle of nowhere... Posts: 78
ta
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
sorry i asked for some advice.
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
Just ignore the cranky old 265s fit perfectly well on the standard alloys and fill the arches a lot better. Height is about the same so no rubbing with standard suspension. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Thanks for that JSG....you have restored my faith in the forum
| AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 793
JSG is right, a 265/75x16 fits just fine, but you may need to look at your lock stops.
I have 265's fitted with 30mm spacers. Andy. |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
265*75*16 on Anthracite zu's Bob |
Cheers guys,very helpful and always good to see pics
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486
255.85s MT will go on to and be ok
or go big big 285 wise. an increase in height will change the gearing dont forget. i run 235.85 ATs and they work well for what i use the truck for. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Oh go on then!!! Hope Disco's not about! Mach 5s foreground Modulars rear! If you go through life with your head in the sand....all people will see is an ar5e!!
(getting own back pedant mode..) i think you will find i'm a 'sensitive SOUL'
Fantastic looking Landy's though
Thank you! Mine and Fekete's taken at Tyneham in Dorset! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 16th Feb 2011 10:59pm. Edited 1 time in total |
