Home > Td5 > Td5 Glow plug relay - part number/llocation
excossack
Not had much joy in searching the parts catalogue looking for the part number of the glow plug relay.
So...anyone know the part number? and also the location of the relay? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #593812 17th Jan 2017 2:12pm
bob neville
This is the relay.
http://www.brit-car.co.uk/product.php?xProd=95302
It is under the drivers seat but not sure which one !
2013 Defender 90 CSW - sold
Post #593817 17th Jan 2017 2:42pm
dorsetsmith
one below is My 2002 and one below that is My1999 to 2001
driver seat box ( MY1999 rave )
working from foot well end
first yellow relay cooling fan
next one yellow relay compresses clutch A/C
next one black relay Glow plugs
next one black relay ABS return pump
next one yellow relay ( main )
canter box fuse box ( MY1999 rave )
working from passenger side
first yellow relay starter
next yellow relay heated rear screen
next yellow relay head lamp
next brown relay sounder alarm
next green relay fuel pump
also ecu delay windscreen wiper unit brown / relay hazed warning black
Post #593819 17th Jan 2017 2:52pm
excossack
Thanks chaps. Is this just a standard relay? 1999 Defender TD5 110
Regards
John M0VAZ
Post #593828 17th Jan 2017 3:47pm
Martin
Site Admin
Standard but the 70 Amp version with the fat power terminals Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #593830 17th Jan 2017 3:56pm
excossack
Thanks. 1999 Defender TD5 110
Regards
John M0VAZ
Post #593856 17th Jan 2017 5:21pm
excossack
By the looks of it, same one as used on a Freelander and Disco 2 1999 Defender TD5 110
Regards
John M0VAZ
Post #593939 17th Jan 2017 9:46pm
Martin
Site Admin
It's a generic part so will be used across the LR range  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #593952 17th Jan 2017 10:10pm
excossack
bob neville wrote:
This is the relay.
Bob
This part number is for a Disco 2 which apparently does not fir a Defender.
The correct part number appears to be PRC6913, so will compare that to the relay in the fusebox to be sure. 1999 Defender TD5 110
Regards
John M0VAZ
Post #594096 18th Jan 2017 2:37pm
rallysteve
I believe PRC6913 is the timer and relay for the TDi models not the TD5 which is ECU controlled and should only be a relay.
Post #594097 18th Jan 2017 2:39pm
excossack
That was from speaking to main dealer and also Dan at Duckworths.....? Maybe because mine is a Jan/1999 model ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #594099 18th Jan 2017 2:41pm
rallysteve
Could well be, I guess the parts system classifies these as to/from VIN number so if yours is close to the cutoff there might be some confusion. PRC6913 is definitely the timer and relay for a TDi which lives under the bonnet on the bulkhead. The TD5 relay is standard size with larger terminals and is under the drivers seat.
Post #594101 18th Jan 2017 2:48pm
Martin
Site Admin
A Td5 definitely uses a standard 70A relay for the glow plugs, the timer function is in the engine ECU.
The Tdi timer ECU/relay unit PRC6913 isn't applicable to the Td5, no matter what year.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #594113 18th Jan 2017 3:47pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
TD5 glow plug relay is controlled from the engine ECU. So just a relay, no timer.
When the engine is cold and runs on low RPM, the ECU energizes glow plugs on running engine. It was a bit surprise for me, hearing unexpected big loud click of some relay, when I was working on 130. In Discovery 2 this is not hear able, the relay is not in seatbox, but in engine compartment. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #594310 19th Jan 2017 9:21am
Martin
Site Admin
That's a couple of times that Dan has quoted the wrong part (unlike him). I wonder if Microcat Live is playing up?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #594386 19th Jan 2017 1:13pm
