Home > In Car Electronics > Puma heater blower, 12v and radio not working
tobz102
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Evening guys. Got in the defender this evening to find that all the above had stopped working. All fuses underneath the steering wheel are fine. Is there a master fuse for accessories I don't no about or a relay perhaps? Any help great fun to make poking around in this weather bareable!! 08 90 puma
Post #593570 16th Jan 2017 7:52pm
dorsetsmith
check supply in to fuse box under driver dash fuse 44 , 45 have conman supply feed for ignition switch aux
Post #593613 16th Jan 2017 9:19pm
tobz102
Thanks,
The common wiring being from Link 5 of the battery junction box all the way through to the central junction box. Out of curiosity and only if you have it to hand, any idea what else comes through link 5?
Post #593627 16th Jan 2017 9:40pm
dorsetsmith
link 5 feeds ignition switch will the engine start ?
Post #593629 16th Jan 2017 9:43pm
tobz102
Engine fired fine and everything else seemed to be fine. I'll check for voltage at the fuse and work back from there
Thanks for your help!
Post #593634 16th Jan 2017 9:49pm
dorsetsmith
link 5 only feeds ignition switch
Post #593639 16th Jan 2017 9:53pm
HardCharger
When you turn the key, do they turn on in some positions? Sounds like you need a new ignition switch. I've experienced this a few times and the ignition switch was always the culprit. I hope this helps.
Post #593723 17th Jan 2017 3:59am
tobz102
Bow down
Works fine in pos 1 not pos 2. New switch it is.
Post #593762 17th Jan 2017 9:31am
tobz102
Having looked at replacing the ignition switch, I'm curious whether it's possible to replace the switch with the barrel still in situ? Most forum posts I've seen have removed the entire barrel (and therefore shear bolts) first then swapped the switch over. I didn't no if it's possible to just remove the switch.
Post #593770 17th Jan 2017 10:13am
dorsetsmith
Two small screw 2mm used to hold ignition switch in too the locking part you can remove them (but) Censored
Post #593778 17th Jan 2017 10:56am
tobz102
Haha, ok I've purchased the switch and replacement shear bolts. I'll attempt it in place but remove if needed...
Post #593801 17th Jan 2017 12:47pm
Martin
Site Admin
I tried it on my soft top without removing the lock etc and could not access the bottom tiny screw whatsoever.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #593824 17th Jan 2017 3:33pm
tobz102
Cheers Martin,
Did you have a preferred method for removing the shear bolts?
Post #593827 17th Jan 2017 3:45pm
Martin
Site Admin
I was lucky, mine was not fitted with shear bolts (sorry)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #593829 17th Jan 2017 3:55pm
tobz102
Has anyone done this on a puma specifically? The workshop manual says nothing about removing the barrel and mentions removing a 'single screw from the ignition switch' as opposed to the 2 dorsetsmith mentioned.
Parts catalogue is showing LR039638 for the switch, which may be puma specific with just one screw? Perhaps they became aware how likely they were to fail/burn out so made it easier to replace Laughing
Post #593914 17th Jan 2017 8:47pm
