![]() | Home > Stolen > Spotted today abandoned on a lane in wales |
| Bows Member Since: 07 May 2012 Location: Wales Posts: 525
Possibly just stuck, and owner had to leave it there to arrange recovery, 2006 TD5110 station wagon
1995 300Tdi 90 truck cab 1989 90 hard top with 200 tdi 1983 110 hard top 1983 110 Hi cap 1954 107 pick up |
| defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629
It has a winch !!!
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
...and no trees to winch it out, and probably too wet to use a ground anchor SKIP
https://www.defender2.net/forum/topic83242.html |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18051
It has an illegal front number plate too.
When night falls it will be parked on an unlight right-of-way after the hours of darkness without lights. Shocking, definitely should be reported. Hopefully by now the owner will have found a grown-up to help to recover it. |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
Classic case of "all the gear no idea"
Wanted, Forward Control Anything considered. |
Not quite all the gear...Assume also there was no second Vehicle with this outing...
SKIP
Yes "it has a winch!!!" but as previously mentioned, doesn't look like there's anything to winch off. It appears to be a good example of why you shouldn't go greenlaning alone. 2006 TD5110 station wagon
| gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654
poor
2009 - current .... 2005 zx10r |
| amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452
There were no trees your all correct.
It was odd that the car had been left unlocked too??? As said I reported to police but they did not tell me if it was recorded as stolen or not. |
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967
Maybe thats because YOURE NOT THE POLICE
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
stolen and abandon then stuck
Pull Pal ground anchor for use in soft ground conditions or as others have said don't go alone. Of course if its been nicked.......
I wonder if they had a spade or shovel (the first piece of recovery equipment you should carry) with them.
You'd have that out in no time with a spade! |
| AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1373
Nothing to say he hasn't snapped a prop or a diff has broke
| All times are GMT |
