![]() | Home > In Car Electronics > Window lift switch connector shells/inserts |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 588 ![]() ![]() ![]() |
Looks like a "Multi-lock 070 6 pin Female Connector" maybe?
First hit on google: http://www.cycleterminal.com/amp-multilock-070.html “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!†- Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6691 ![]() ![]() ![]() |
If you get stuck I can get them in white or black rather than the pale green
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
Thanks guys, I must have spent nearly a day trying (unsuccessfully) to find those on the internet!
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
https://www.simtekuk.co.uk/product.php/070...:::1722681 02' 110 TD5 Double Cab Rebuild Thread
Thanks everyone, I have now ordered some up from simtekuk.
Most grateful! ![]() |
![]() I'll add some to the site shop ![]() ![]() |
Sorry Martin if I misread the tenor of your email, I took it to mean that you'd rather not bother if I could get some elsewhere, but were willing to get some if I was stuck! I dodn't mean to cause a glum face!
With the number of people now who reconfigure their dashboards, add electric windows, etc, having a selection of these on the forum shop would I feel be a populer move. Thank you, and sorry! |
No worries, I'll be stocking these from Monday
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
Martin - You should put up for sale Econoseal and Superseal connectors too.
They are always in demand for various things, I'm sure they would sell. Plus of course the OE type of connectors like BW was looking for. ![]() ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
I too have been trying to reach PaulMc for some time without any success.
Are there male connectors to these to create a plug and play loom for the extension of some of the dash switches on the TDCi ie. rear wash and wipe as well as front and rear heated screens or should I just cut off the existing plugs and extend the wires? All help appreciated. |
An update to this thread.....
The window lift switch connectors are in fact NOT AMP Multi-lock 070 6 pin Female Connectors as suggested above, because the ones I ordered have arrived and are much smaller than those required! ![]() Martin, I will now be ordering from the forum shop after all! I presume that the ones you list are in fact the correct ones, not the same incorrect Multi-lock 070 ones I bought from Simtek. |
Hold off and I will double-check mine
I've got a switch off my Puma and the connectors I have got look right. I will confirm in an hour when I get to the connectors themselves.
Nope my ones are too small as well
![]() I will track down the correct ones if I can. Martin ![]() ![]() |
