Home > Td5 > new fuel pump,cleand out harness now running s**t...help
Page 6 of 6 <123456
lozza
injectors checked by me and the indi guy with posh diagnostic
Post #591221 8th Jan 2017 11:48am
bob neville
lozza wrote:
was told by mechanic crank sensor eather works or not
loz
Sorry but that is not correct ! My TD5 had flat spots and missed at 2000 rpm. Up to 2000 rpm it was fine, maybe a bit sluggish, but still OK to drive. The cause - crank shaft sensor !!! They can be an on/off type fault but I have helped a few people now with running issues on TD5's and probably a third of them had a sensor problem or the famous missing shim that was the subject of a LR recall.
I am not saying this is your problem but the mechanic should not have dismissed it - it takes minutes to check if it is OK and the shim is present !
2013 Defender 90 CSW - sold
Post #591585 9th Jan 2017 5:52pm
grafty99
Have you got another fuel pump to try? It is the title of this thread! assuming everything was ok before the pump change? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #591610 9th Jan 2017 6:53pm
excossack
I assume the pipes have been connected the correct way around on the pump after the change? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #591656 9th Jan 2017 9:26pm
mk1collector
I've asked both of those questions Whistle Ray
My build thread
Post #591659 9th Jan 2017 9:31pm
excossack
I didn't spot that! 1999 Defender TD5 110
Regards
John M0VAZ
Post #591662 9th Jan 2017 9:50pm
mk1collector
He's very adamant that there's nothing wrong with the pump Thumbs Up Ray
My build thread
Post #591669 9th Jan 2017 10:06pm
lozza
right guys,did the injector seals today and.............. and............. fixed at last,all were worn after 150k so touch wood thats all fixed,thanks for all the advice,new clutch fly wheel and disco transfer box this year so no doubt ill be asking for advice again
thanks
loz
Post #591914 10th Jan 2017 8:42pm
bob neville
Result Thumbs Up
Post #591955 10th Jan 2017 10:18pm
lozza
went out this morning ....instant start.....bang on
loz
Post #592051 11th Jan 2017 10:45am
Page 6 of 6 <123456
