| daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246
Yeah - spotted a trail of water from the lower nut on the driver's side. In addition, the washer on the lower nut showed the beginning of corrosion - other 2 nuts & washer are fine. Will see what happens. If this does not work, might be the Naka double door seals would be a worthwhile investment. 2001 TD5 110 DCPU in Bonatti Grey |
| G4sweep Member Since: 24 Sep 2010 Location: Paderborn Posts: 182
A solution to footwell rain!? I'll give this a shot. Many thanks for the info. Sweep
2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253
Changed the track rod I bent last week for one of Gwyns heavy duty ones
Click image to enlarge |
| TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715
A combination of Weetabix and Spinach (and no hangover) |
| warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903
PICKED IT UP
Been without it for what seems like weeks! After putting quite a lot of miles on the courtesy F2 in comfort, I've had to re-deform to fit the Defender but it feels like home again! Like being inside an old friend, so to speak.... It's had a new gearbox and output shaft, roof has been touched up where the paint was peeling and the wing mirror arm has been replaced, so hopefully that will be the end of all it's issues now Wasn't able to take the long route home (valentines day or something... pfft) but I'm in Liverpool tomorrow and Whitby later this week so that'll make up for it! |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
Myself and my sales guy took a D4 on a 500 mile round trip today as J-Lo is at the doctors. This is the first time my sales guy has been in a D4, get this, about 30 miles into the trip he turned to me and said "The blue Land Rover is a lot more comfortable isn't it" I had to agree the D4 rocks side to side quite a bit. 130's have feeling's as well you know
| mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109
Mine were leaking there got the dealer to get some more gaskets fitted seems ok now |
I have the same problem going from mine to the wifes D4 i even complained to the dealer saying there is something wrong with the D4 steering its just so sharp the slightest movement and your off were the 130 has a bit of play which is fine |
| TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045
Fitted a Mantec rear window Guard, just waiting for my new wheels
Fitted a few wee bits n bobs ordered from Mud - only placed it yesterday afternoon, got here first thing this morning.
Planning on the great ICE install now. 2001 TD5 110 DCPU in Bonatti Grey |
| BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518
ordered some carpets from Britpart and waiting for them to arrive soon.....
| alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513
Rope You can swing a tyre onto your shoulder and pass it up to someone who's already up there but if you're on your own, haul it up. Never drop a tyre off the roof - it'll bounce very high and is lethal + New Defender 110 First Edition |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
Tack how did you fit the guard? Did you rivet it in place? Russell Russell 2011MY 110 XS USW Black |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
makes sense, not sure i would want that amount of weight that high up. always wondered how a fully spec'd Defender would react with loads of weight in it and on the roof. having seen some of the Camel videos they seem very unstable |
| All times are GMT |
