![]() | Home > Technical > Steering wheel vibration |
If all the above has not worked have you tried the King pins? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Gozy Member Since: 02 Apr 2016 Location: Sidbury Posts: 43 ![]() ![]() ![]() |
Thanks will check them out. Have also been told the cv joints maybe the problem but haven't any noises from them !
One other thing it could be is the steering damper. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
CamRSA Member Since: 24 Aug 2016 Location: Devon Posts: 66 ![]() ![]() ![]() |
Same issue at the same speed. I'm going to look into it as soon as I have time but any experience on here is great. I'm
I did change the steering damper about 10 months ago. That was the first thing I did. Cheers.
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
Had the same thing a few years back and did the same things over time - balanced wheels, new steering damper, bushes replaced and so on. No change.
I then got the swivels serviced and pre-load set properly and it completely solved it. Dave Green Goddess - 1998 Defender 110 300tdi |
Thanks Dave seems to be the way to go. Will post the the result when done.
Finally got round to this. Started with the obvious, balancing, got lucky and it seems good to go now. Just thought I would update.
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Some people said that a culprit are warped brake disks (I'm not sure if 2004 model have it) but worth to check. Eduardo
MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
I have that problem regularly, my problem is always the same and simply to resolve. I have regularly mud in my rims.
![]() ![]() Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
