Home > Technical > Steering wheel vibration
Gozy
United Kingdom 2004 Defender 90 Td5 SW Aintree Green
Need help please. I have steering wheel vibration starting at 55mph to 65 ish. The off side inside edge of the front tyre is wearing. I have had the wheels balanced tracking checked all ok. A wheel bearing has been tightened and a new ball joint fitted. Still have the problem. I then was told that the tyres I had on were 7 years old and maybe the problem. Have now fitted new bf Goodrich all train on wolf rims but the problem still remains.
Post #567205 28th Sep 2016 3:48am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
If all the above has not worked have you tried the King pins? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #567207 28th Sep 2016 6:06am
Gozy
Thanks will check them out. Have also been told the cv joints maybe the problem but haven't any noises from them !
Post #567695 29th Sep 2016 10:09pm
Mash
One other thing it could be is the steering damper. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #567706 29th Sep 2016 10:31pm
CamRSA
United Kingdom 2004 Defender 110 Td5 DCPU Alaska White
Same issue at the same speed. I'm going to look into it as soon as I have time but any experience on here is great. I'm
Post #567708 29th Sep 2016 10:40pm
Gozy
I did change the steering damper about 10 months ago. That was the first thing I did. Cheers.
Post #567709 29th Sep 2016 10:41pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Had the same thing a few years back and did the same things over time - balanced wheels, new steering damper, bushes replaced and so on. No change.
I then got the swivels serviced and pre-load set properly and it completely solved it. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #567735 30th Sep 2016 6:06am
Gozy
Thanks Dave seems to be the way to go. Will post the the result when done.
Post #567933 30th Sep 2016 10:33pm
CamRSA
Finally got round to this. Started with the obvious, balancing, got lucky and it seems good to go now. Just thought I would update.
Post #590805 6th Jan 2017 8:23pm
Eduardo
Some people said that a culprit are warped brake disks (I'm not sure if 2004 model have it) but worth to check. Eduardo
Post #590815 6th Jan 2017 9:07pm
roel
I have that problem regularly, my problem is always the same and simply to resolve. I have regularly mud in my rims. Twisted Evil
 Roel
2003 90 Td5 (2009-now)
Post #590822 6th Jan 2017 9:26pm
