![]() | Home > Maintenance & Modifications > LED Head Lights |
| nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546
or a 240W LED lightbar wich equals to 1320W Halogen! Eyecandy! WANTED:
SII or SIII in max 1.5k |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
IID Pro MV License |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Pete yes they will but you have a few options for side lights .... the JWS8700s (LED Headlights) don't have a side light so I am planning on replacing the spot light unit (90mm) for one with a sidelight bulb in it (as well as the spot light), they are available from hella. then it's a case of relocating the side light to the spot and fitting the 8700's = happy driving at night, but hella are also launching a LED headlight this year so I am sitting on my wallet for a while. another option is to fix e marked side lights or doing the DRL thing ... or having the headlights come on with the ignition .. not sure about all the legalities of these options. |
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
Thanks for that BPman. I'd completely forgotten that the SVX headlights contain the sidelight too, hence having to perfom a secondary modification. I like your idea about changing the drving lamp for one with an integral sidelight although being Hella units they're probably a bit pricey I suspect. I may wait too to see what their LED headlights are like.
Pete |
the 90mm spot lights with side lights - here are the details from the hella web site
Part no: 1K0 247 043-001 Headlight EAN 4082300246582 Status Normal Packing Unit 1 Trade Numbers E1 2397 Criteria: Number of light functions 2 Manufacturer Restriction Ref. 12,5 Bulb Type H1 Rated Voltage [V] 12 Light Function with high beam Light Function with position light Light Design FF Light Design Halogen Mounting Type Fitting inspection Tag E1 2397 inspection Tag ECE the hella web site is not easy to navigate but this looks to be the correct unit, or course the other option is to "manually" fit the sidelight unit to the existing 90mm unit without breaking it ... |
| Wizard Sleeve Member Since: 02 May 2011 Location: Berkshire Posts: 25
Hi could I see a picture of what they look like on your SVX. Was thinking about some of these for mine Lee |
| All times are GMT |
