Home > Maintenance & Modifications > LED Head Lights
Page 2 of 2 <12
nakatanenga
Germany
or a 240W LED lightbar wich equals to 1320W Halogen! Eyecandy! WANTED:
SII or SIII in max 1.5k
Post #58726 12th Feb 2011 9:14pm
dgardel
Italy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #58745 12th Feb 2011 11:34pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Does anyone know if these will fit behind the SVX headlight surrounds? If they do I think I'm going to get saving up!
Pete
Post #58960 14th Feb 2011 8:58am
Pete
Pete
yes they will but you have a few options for side lights .... the JWS8700s (LED Headlights) don't have a side light so I am planning on replacing the spot light unit (90mm) for one with a sidelight bulb in it (as well as the spot light), they are available from hella. then it's a case of relocating the side light to the spot and fitting the 8700's = happy driving at night, but hella are also launching a LED headlight this year so I am sitting on my wallet for a while.
another option is to fix e marked side lights or doing the DRL thing ... or having the headlights come on with the ignition .. not sure about all the legalities of these options.
Post #58992 14th Feb 2011 12:26pm
XS Pete
Thanks for that BPman. I'd completely forgotten that the SVX headlights contain the sidelight too, hence having to perfom a secondary modification. I like your idea about changing the drving lamp for one with an integral sidelight although being Hella units they're probably a bit pricey I suspect. I may wait too to see what their LED headlights are like.
Pete
Post #58995 14th Feb 2011 12:45pm
the 90mm spot lights with side lights - here are the details from the hella web site
Part no: 1K0 247 043-001 Headlight
EAN 4082300246582
Status Normal
Packing Unit 1
Trade Numbers E1 2397
Criteria:
Number of light functions 2
Manufacturer Restriction Ref. 12,5
Bulb Type H1
Rated Voltage [V] 12
Light Function with high beam
Light Function with position light
Light Design FF
Light Design Halogen
Mounting Type Fitting
inspection Tag E1 2397
inspection Tag ECE
the hella web site is not easy to navigate but this looks to be the correct unit, or course the other option is to "manually" fit the sidelight unit to the existing 90mm unit without breaking it ...
Post #59000 14th Feb 2011 12:58pm
Wizard Sleeve
United Kingdom 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Re: LED Head Lights
kljw wrote:
Hi
any one fitted LED lights to there defender as yet? mjust got my self a pair, and there the dogs so to speak. the std lights on my SVX where good. the HID bulbs that i fitted, although illegal, where an improvement, but these are just amazing.
price not cheap, but well worth the spend if you intend to keep your defender or are thinking of buying a replacement defender.
will try and posts some poics of these when i work out how to.
Hi could I see a picture of what they look like on your SVX. Was thinking about some of these for mine
Lee
Post #76721 19th Jun 2011 7:57pm
Page 2 of 2 <12
