Home > Td5 > Miles from fresh tank?
Page 5 of 7 <1234567>
grafty99
I'm not, I buy it by the 5L tub from our local motor factor. It's just cheap carplan stuff. Just need to make sure it's low ash Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #589393 2nd Jan 2017 11:01am
Anderzander
And make sure it's suitable for pre-mix.
Post #589448 2nd Jan 2017 3:23pm
lightning
Post #589649 3rd Jan 2017 8:37am
mactheknife
United Kingdom 2004 Defender 110 2.5 TD CSW Baltic Blue
That's pretty condemning
Post #589815 3rd Jan 2017 7:18pm
roel
I hardly see the light coming on as out of experience I know that going off-road with less than a quater tank of fuel is not a good idea. It will run out of fuel after about 15 minutes in a position like this. Whistle And then you have a bigger problem.
 Roel
2003 90 Td5 (2009-now)
Post #589875 3rd Jan 2017 9:39pm
grafty99
An interesting article but for south african specification diesel.
Whilst the research says there is no benefit. In a fairly basic diesel system like the Td5 it can't do any harm and also looking at the graphs it did increase lubricity and cetane ratings in "market diesel" even if only by a tiny amount.
It definitely makes a difference to injector noise on my 90 so will carry on using it Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #589950 4th Jan 2017 12:00am
grafty99
Yes offroading at those kind of angles half a tank plus is definitely advisable! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #589951 4th Jan 2017 12:02am
roel
I didn't plan that angle, I was doing this but I lost grip. Twisted Evil
 Roel
Post #590033 4th Jan 2017 12:04pm
grafty99
Nice Cool 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #590100 4th Jan 2017 4:45pm
lightning
If it's making the injector noise quieter, it means that it's slowing the combustion process.
Two stroke oil is designed not to be burnt but to lubricate the engine, as a two stroke engine has no oil sump.
ln a diesel it will most likely just slow the combustion process.
Post #590501 5th Jan 2017 9:00pm
grafty99
Two stoke oil lubricates by being physically drawn though the crank case to lubricate the main bearings etc, as it is part of the fuel as well it has to burn or it would eventually coke the combustion chamber and exhaust completely (will do on a motocross bike if you don't use it hard enough)
Once a two stoke is up to running temperature the blue haze of smoke from the exhaust clears as it burns completely which it doesn't when cold hence the smoke.
If it lubricates an otherwise dry sump then it must be lubricating the fuel system. If it slowed combustion would it not make it smoke as the diesel would not fully combust? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #590563 5th Jan 2017 11:18pm
grafty99
A picture of this tank full. Not really trying on this tank so in the orange now at 354 miles I'm guessing around 29.5mpg for this tank so might not get 400 miles but next tank I'll really try. Who knows might be able to squeeze 420 miles out of it Twisted Evil
1990 Vogue SE
Post #590564 5th Jan 2017 11:21pm
lightning
I get about 26 mpg from my TD5 110 in local stop start driving.
l recently had it remapped and if l drive it using the extra torque l get 1-2mpg less.
lf l drive it as before, fuel consumption remains at 26mpg.
On the motorway l get.....26mpg. But l drive at 65-70mph on the motorway so only to be expected.
I was told by my local LR specialist dealer NOT to put two stroke oil in a TD5 as it will eventually damage the injectors.
I used to put it in my Transit Connect tdci and it did seem to make the engine a bit smoother. But then l read the article l posted above and stopped using it.
Post #590609 6th Jan 2017 8:26am
grafty99
I find it hard to get my head around the advice that extra lubrication can damage a component. Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #590623 6th Jan 2017 9:43am
grafty99
However if I could see evidence to show that adding 2 stroke oil to a vehicle directly caused "x" fuel component to fail then I would consider stop using it.
I find premium fuels have a similar effect, these have extra additives for lubrication too 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #590624 6th Jan 2017 9:47am
