![]() | Home > Puma (Tdci) > Washer jets |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Another alternative is to use the Peugeot jets that fit onto the arms and have many jets direct onto the screen
| Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226
@Retro - is that just a single standard LR washer pump? 2005 Td5 | 90 Station Wagon | Tonga Green
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513
Upto the TD5 the bulkhead has 9mm holes where you can put the jets in. From the Puma there are different and much bigger holes, with an awkward shape. In these holes you can't put the regular jets, therefore i designed a spacer (hopefully i get the foto in this post
Click image to enlarge Click image to enlarge [/img] Yesss eureka! photo's displayed |
@Retro Thanks, looks spot on in your YouTube clip - massive improvement. Mine's going in for the mod next week. Been thinking about it for ages, but now that the winter grime has set in again I can't put up with the useless single washer any longer. 2005 Td5 | 90 Station Wagon | Tonga Green
| John Fair Member Since: 10 May 2016 Location: Norfolk Posts: 150
Ref dash not having to come out in a puma- on mine I removed the center console (2 screws, pull to remove clips, remove wiring blocks), I then removed the metal bracket blocking the view of the back of the washer jet ( 8mm bolt, 4x plastic Christmas tree screw things with plugs) and simply tightened the washer jet mount with a 13mm deep socket after pulling pipe off the rear. Hopefully this helps someone. Realistically 15/20mins. Oh and a flashlight.
Click image to enlarge |
| Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696
John that's priceless news!
I was going to have a go and see if I could see a way through it as I have had the center part of the dash out a few times for radio fitting and thought it couldn't be far away - now I know it is possible that's a massive help!!! Top Man !!!!! And Top Forum too Martin !!!! |
| Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697
TDi4 - Please could you explain how you fitted those without the dash removal. Are they glued in place?
| flydive Member Since: 27 Aug 2015 Location: Lugano Posts: 290
Would you be willing to share the stl file? I do not need it now, but someone might. |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4804
Another simple upgrade is to fit the red top rear washer pump to the front as this is more powerful than the black topped standard one apparently... 2002 90 Td5 Station Wagon
I did swap mine round and it made a difference.
Very easy to do - IIRC there are joints on the pipes between the heater and inner wing on the puma that made it easier that reaching through to the actual pumps. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18052
Absolute top tip, thanks! My nozzle popped off in the frost yesterday whe I squirted the screen, I heard it rattle off the bonnet and bounce under a back wheel. Using John's method it only took 20 minutes to fit a new one. I didn't bother replacing the pressed steel bracket since the upgraded head unit doesn't it for support and it appears to do nothing else useful. Anyone know a part number for the bit that pops off? Anyone fitted (heated) bonnet jets or know of suitable ones? |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
http://www.paddockspares.com/dnj500270-kit-jet.html Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Thank you.
For some reason the front part on its own is more expensive than the complete assembly. |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
But rear spray use a different pump..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| All times are GMT |
