![]() | Home > Puma (Tdci) > Oil smells of diesel. What to check? |
I thought that is how the oil service light came on on a puma. When the oil had a certain amount of diesel in it it needs changing. I think I read it somewhere and didn't dream it
![]() My build thread http://www.defender2.net/forum/topic17615.html |
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 ![]() ![]() |
Thanks! No oil service light yet - albeit I am not sure I have such an indicator, it's a 07 2.4 TDCi -
That's indeed so for the 2.2 TDCi, but not for the 2.4. The 2.2 gets diesel contamination due to the DPF recycling, the 2.4 does not have that.... feature. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17863 ![]() ![]() ![]() |
To be honest if it is a faint smell I wouldn't worry about it, but I would keep a close eye on the oil level. If it goes up, then investigation is called for.
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Could be injector seals
Ah didn't realise it was different for the 2.4 Ray My build thread http://www.defender2.net/forum/topic17615.html |
I find it quite funny that such an oil service light exists
![]() But it fits with the rest of the Defender. Injector seals might be it. Aren't they the same as the copper gaskets sealing the injector towards the fuel lines? I am having injector trouble anyway (cyl. 1+3 are knocking and are slightly out of tolerance), so everything will have to come out for four new injectors on Jan. 5th anyway... Have a good New Years Eve everyone! |
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 ![]() ![]() |
I think not. My service light simply corresponds with time and mileage. I click the service light away and leave oil as is. Light won't come up again before time or mileage are 'service-critical' once more. Hence quality is not the issue (in my case at least) ![]() |
