Home > Td5 > Miles from fresh tank?
Page 1 of 7 1234567>
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
How many miles do people get between fill ups with their TD5? I am trying to work out if I have an issue with my fuel economy
Thanks
Post #588548 29th Dec 2016 9:24pm
ibexman
Around 300
Post #588554 29th Dec 2016 9:38pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Routinely get 600kms per tank with low light just coming on. Mainly 7 Kms twice per day to work.
Post #588558 29th Dec 2016 9:43pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
I recommend Fuelly.com to track the fuel usage. Its how I used to spot issues with my Disco.
I have only done 1k miles so not much data yet. But,
My averages so far,
364miles, 66.2ltr, 24.8mpg.
Post #588570 29th Dec 2016 10:13pm
jrule
Thanks interesting I know the 90 and 110 have different sized tanks however following filling up my 90 to the brim the light comes on after 260 miles…I have checked for leaks and nothing visible. Have also unplugged the MAF so was thinking maybe egr or injector seals?
Post #588573 29th Dec 2016 10:23pm
JustFX
Injector seals, I wouldn't jump to that unless you are getting derv in the oil.
I always found an oil and filter change (including Fuel) made a difference to MPG. But best to look at stuff that is affecting the engine. Belt tensioners wear, or alternator could be working hard, drag from anything on the engine. Brakes dragging from the calliper pins worn.
Rubbish fuel doesn't help either.
Then MAF, MAP sensors could do with a clean (electrical cleaner to remove oil etc). Intercooler Flush/Clean.
Post #588587 29th Dec 2016 10:47pm
excossack
I get around 300 to a full tank. (110) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #588590 29th Dec 2016 10:58pm
Tiger
340 to 360
26-28mpg
110
Post #588596 30th Dec 2016 12:43am
mk1collector
Used to get 340 every tank but it seems to have dropped to around 310 since the weather got cold Rolling Eyes I measure from full till the light comes on. Ray
My build thread
Post #588599 30th Dec 2016 1:03am
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Mmm, I was getting 380+ to a tank.
I'm getting roughly the same with my 2.4 Puma.
Andy
Post #588612 30th Dec 2016 8:34am
isacs
I would get 280ish if I drove like my dad. In a 90
Post #588614 30th Dec 2016 8:44am
barbel jim
Me.......240ish
The wife 280 ish
Caterham 2800 ish
Worth mentioning the 2.2 is the same, sometimes worse !!!!
Post #588621 30th Dec 2016 9:42am
Tiger
Tiger wrote:
340 to 360
26-28mpg
110
This is full to light also so should be another 20-40 miles to empty
Post #588627 30th Dec 2016 10:07am
xcentric
barbel jim wrote:
Caterham 2800 ish
Shocked
I'd tentatively suggest that you're not driving it properly if you get that mileage from a tankful..... Rolling with laughter Rolling with laughter
Post #588642 30th Dec 2016 11:10am
grafty99
About 380 from my 90 maybe 400 at a push 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #588646 30th Dec 2016 11:22am
