![]() | Home > Technical > Daylight running lights - what have I done wrong? |
| Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396
I have just fitted as set of LED DRL's.My vehicle is a 2007 Tdci 90.
There are basically 3 wires to fit the DRL module - earth , ignition switched Pos ( picked up from my aircon switch & the remaining wire to one of the headlights ( mine are LED made by RVX ) so not cheap lights. I have just one DRL flashing & the other not lit. I assume....that the only wire that I can have got wrong is the headlight wire ; if so what have I done?. OR is the module faulty. Any suggestions please as to what to check next. TIA Guy |
Faulty earth - so ran an earth back to the battery- problem solved.
Guy |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Thanks for coming back with the fix
| All times are GMT |
