Home > Technical > Daylight running lights - what have I done wrong?
Chopperone
I have just fitted as set of LED DRL's.My vehicle is a 2007 Tdci 90.
There are basically 3 wires to fit the DRL module - earth , ignition switched Pos ( picked up from my aircon switch & the remaining wire to one of the headlights ( mine are LED made by RVX ) so not cheap lights.
I have just one DRL flashing & the other not lit.
I assume....that the only wire that I can have got wrong is the headlight wire ; if so what have I done?.
OR is the module faulty.
Any suggestions please as to what to check next.
TIA
Guy
Post #585351 15th Dec 2016 5:30pm
Chopperone
Faulty earth - so ran an earth back to the battery- problem solved.
Guy
Post #588086 28th Dec 2016 7:16am
mk1collector
Thanks for coming back with the fix Thumbs Up Ray
My build thread
Post #588116 28th Dec 2016 11:03am
