Home > Maintenance & Modifications > Headlights
Page 3 of 4 <1234>
BW - I was thinking that, direct battery feed with a decent gauge cable would have very little losses to it just the same.
This is how my spots are fed, drawing 200w.
I notice the Land Reiziger loom has what appears to be a waterproof in-line fuse, which is great but the Boomslang doesn't appear to though.
I suppose one could easily remove and re-wire to battery or fusebox or similar at a later date.
I might need to do that at some point anyway.
Trouble is in the battery box there is limited room & I have a 4 gauge Amp cable and in-line AFS fuse there too.
At least once fitted there is no need to remove headlights, and agree plastic connectors would be fine.
Depends on price difference to Ceramic, might just go for the latter if it's negligible.
Might be a good excuse to get a set of crows foot spanners, may aid access or at least an excuse to. Whistle
I only have adjustable wrenches, torque wrenches and socket sets.
Why does the TDCi always need to be a pain to get access. Laughing _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #587585 25th Dec 2016 8:04pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Actually cheaper for the ceramic connectors - best of both worlds Thumbs Up
Post #587592 25th Dec 2016 8:44pm
I found that there was ample room for the aux fusebox between the battery and the side panel of the battery box (the panel that the door shuts against), in what is otherwise completely wasted space.
There is a single feed from the +ve terminal to the fusebox (iirc 25mm^2 or thereabouts), now if I need additional fused unswitched feeds I can get them very easy. One position is used for a hardwired socket for a Ctek charger.
When I get the chance I can post a pic if it would be of any interest.
This, although not cheap, is an incredibly useful addition to a Puna Defender owner's toolbox:
https://www.machinemart.co.uk/p/facom-67sj...y-combina/
Post #587600 25th Dec 2016 10:24pm
I know the area you mean, but viewing fuses can't be easy?
They look good. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #587614 26th Dec 2016 12:41am
LR90XS2011
this is from memory but I think the Land Reziger loom is designed to go to the alternator and wont reach the battery, I'm fairly sure I had to extend mine as I wanted to go to the battery , it does indeed come with an in line fuse and ring connector for connecting to the alternator but I went straight to the +VE battery terminal via an existing hole in the seat box. this left the fuse near the terminal fusing the whole cable etx and making it fairly easy to get to if you should ever need to.
extending requires some wire the same gauge and some plastic flexible conduit, looks nice and original when done DEFENDER 90 TDCI XS,
Post #587622 26th Dec 2016 9:20am
Bluest
Just to confirm, the Landreiziger loom only has just enough cable to reach the alternator, which is how I installed it. 2007 110 TDCi Station Wagon XS
Post #587640 26th Dec 2016 10:45am
Thumbs Up
When I did my spots I used 3mm thinwall I think if I remember rightly.
I put that through flexi conduit too.
I think for the time being if I go for it I will just go for the alternator, I could extend at a later date.
I'm just waiting to the new year to get the bits hopefully. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #587652 26th Dec 2016 12:05pm
leeds
custom90steve wrote:
What H4 connectors do Noldens have?
I agree on Ceramic only for 100w but then they aren't legal anyway.
I guess if Noldens are plastic the Landreiziger loom may as well too.
The H4 connector on the back off the Noldens is built into the aluminium heat sink so I do not think that heat there will be an issue.
As an aside how much of an issue is the main headlight switch? Have replaced switch twice in 20 years. It is a good idea to have some additional lights not wired through main beam. OK maybe not strictly road legal but a good back up.
Fitted a set of Noldens to our 96 plate 110 and very pleased with them. No improved wiring loom, just plugged them in.
Brendan
Post #587703 26th Dec 2016 4:27pm
Brendan - I agree with the switch, it is far over done.
Never had an issue, nit likely too but as we know anything could break.
Personally I'm not over worried about it.
I'm just wondering if there is a benefit from one of the upgraded looms with Noldens or not.
Whilst they have a regulated driver they do still draw a current and I'm wondering how much losses maybe incurred in that due to the OE loom.
I suppose I'm thinking of the loom due to taking everything out and fit and forget. But I am wondering if the expense of add on looswould be worthwhile or even they there would be the slightest difference.
It's obvious with Halogen the looms are an improvement with reduced voltage losses and resistance but with LED's things aren't quite so black and white.
I'm definitely getting the Noldens, just trying to make my mind up on the additional loom.
I'm tending to think just suck it up, go for it and have done with it fit and forget both at the same time.
Then finally I'll have all bits I've ever wanted.
Noldens, SS bezzels, SS fixing kit, Land Reigziger loom.
Then I can go and get a life and start living again. Rolling with laughter _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #587721 26th Dec 2016 5:15pm
Pickles
If anyone is looking at a loom upgrade, then google "Traxide". They are much respected in Aussie, & make various loom upgrades & other stuff for Defenders. Never heard a bad word about them.
Pickles.
Post #587837 26th Dec 2016 10:49pm
ericvv
A bit off topic, but not entirely. Last few days during travels have been driving an Evoque with standard factory halogen headlights.
They are probably less good than my SVX Cristals with the premium Land Rover H4 bulbs and my Landreiziger loom. Just to show that you can do pretty well with bringing a Defender up to modern standards.
I will stick to my current setup for original look reasons, and for the fact that I never liked running my Speaker LED in combo with the factory 90 mm halogen driving lamps. A pity that no LED lights manufacturer ever cared to develop a LED replacement for the SVX, Raw, Fire, Ice 90 mm driving lamps. I am the first to admit that LED are better than anything else, but my hopes for a full front LED setup have been squashed long time ago.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #587905 27th Dec 2016 8:38am
I know it can be a pain to get a match, it was like the side repeaters at one time.
But when they were developed. ( at great cost!) they were a great addition. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #587922 27th Dec 2016 10:10am
OleDave
United Kingdom 2007 Defender 90 Puma 2.4 CSW Indus Silver
Hi Guys and girls, hope you all had a lovely few days.
Well now I am over the turkey, sausage and stuffing and recovered from an over indulgance of the vodka I eventually have had time to think which route I wish to take following all your replies and some research of my own.
It appears from my searches and listening to people on this fantastic site that there is little info on LED and not a hugh experience of the LED headlight concept or for that matter much love of the technology, however I have to admit that I have learned a lot from the comments offered and from my own research I have come to a conclusion on the route I will be taking.
The LED option initially looked very interesting and seemed to offer greater benifit over halogen but it was noticable that there was not a lot of interest here in going that route or splashing out the cash, so after careful consideration and weighing up the benifits against the cost which was around £300/400 for a set of full LED headlights, I have finally come to a decision, The Decision......: I do not consider the outlay for LED is currently worth trying without more info or people having testing the concept, so my route will be crystal lenses and an uprated harness to inject the full voltage to a halogen set up as discussed often on the posts.
So there we are guys and girls Very soon I will order the new lenses and the harness as I am sure it has to be better than the candles I have at the moment.
In conclusion many thanks to you all for the comments and the advice, as usual I am glad I actioned the post, as again I have learned a lot from all you experienced people which has helped in my final decision.
Happy New Year to you all
Grateful Ole Dave
Post #588005 27th Dec 2016 7:15pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Front all LED setup...
What it would look like:
Post #588009 27th Dec 2016 8:02pm
That's how lighting wise I wan mine ^^^^ although sticking with halogen spots for the time being at a later date will likely experiment.
Dave - Wise choice, you'll get the best bang for buck so to speak for expenditure that way.
And as you'll have the loom fitted, if you do at a later date want to go LED you have the loom already fitted and you could sell the Crystals.
In the meantime you will have a very good, improved set up.
You may even wish to stick to it.
What LED headlights were you looking at?
Not sure what Speakers are but Noldens are neigh on £600, costly but appreciate their lumen output, design work and R&D put into them. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #588023 27th Dec 2016 8:58pm
Page 3 of 4 <1234>
