![]() | Home > Maintenance & Modifications > Headlights |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Why going through the trouble of wiring through the firewall all the way to the battery if you can wire to a permanent live on the alternator in the engine compartment where you need to be anyway? That alternator permanent live is in direct contact with the battery anyway, so why bother making it more difficult? No advantage at all.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21039
Fuse placement is better access and avoids messing around with the alternator.
Just my preferred method to keep everything located where I want it. I've got a feed coming through anyway through the bulkhead so I can easily follow with another. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| All times are GMT |
