![]() | Home > Maintenance & Modifications > Installing headlight relays - for the novice! |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
When I get round to sorting mine, I plan to take a permanent feed from the alternator, fuse it there to 30A.
From there into the relay. Trigger the relay using the existing wires feeding the headlight plugs. Earths all back to a convenient bolt on the engine block. Splice the output of the relays into the original headlight plug wiring with either heatshrink butt crimps or solder and heatshrink. If none of that makes any sense I'll get a diagram sorted! |
mactheknife Member Since: 08 Jul 2016 Location: Somerset Posts: 51 ![]() ![]() ![]() |
Thanks Miker.
I'll have a look for a suitable point on the alternator to tap into |
The output terminal is from memory an m8 stud. Has two wires coming off it, one from the battery, one to the starter!
Ah that was the bit I was missing!
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
I've just received a kit from LandReiziger to do this, it's plug and play. I used to make looms etc for my older cars, but buying quality off the shelf items now is so much easier and in most cases tidier. You should have a look for them.
Thanks Roddy, just been having a look on their site
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4332 ![]() ![]() ![]() |
Just make sure you disconnect the battery before going anywhere near that stud on the alternator. I speak from experience
Hahaha, noted!
Scrawf Member Since: 24 Jul 2016 Location: Matlock Posts: 25 ![]() ![]() ![]() |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
By "Gegio" from defendertricks.com
![]() Click image to enlarge https://defendertricks.com/2012/03/01/solu...che-fonde/ and youtube video : Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Thank you Marco.
![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
