Home > Maintenance & Modifications > Installing headlight relays - for the novice!
mactheknife
United Kingdom 2004 Defender 110 2.5 TD CSW Baltic Blue
Having just had to replace a headlight switch in my TD5 as it burnt out I'm planning on adding some relays to prevent a recurrence.
Has anyone got any simple guides on how to do it?
I've had a search about and there are some guides, however I'm struggling with good points to connect into the existing loom.
Any pointers in the right direction would be appreciated.
Many thanks in advance.
Post #586271 19th Dec 2016 12:51am
miker
When I get round to sorting mine, I plan to take a permanent feed from the alternator, fuse it there to 30A.
From there into the relay.
Trigger the relay using the existing wires feeding the headlight plugs.
Earths all back to a convenient bolt on the engine block.
Splice the output of the relays into the original headlight plug wiring with either heatshrink butt crimps or solder and heatshrink.
If none of that makes any sense I'll get a diagram sorted!
Post #586274 19th Dec 2016 12:59am
mactheknife
Thanks Miker.
I'll have a look for a suitable point on the alternator to tap into
Post #586277 19th Dec 2016 1:27am
miker
The output terminal is from memory an m8 stud. Has two wires coming off it, one from the battery, one to the starter!
Post #586278 19th Dec 2016 1:45am
mactheknife
Ah that was the bit I was missing!
Post #586279 19th Dec 2016 1:52am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
I've just received a kit from LandReiziger to do this, it's plug and play. I used to make looms etc for my older cars, but buying quality off the shelf items now is so much easier and in most cases tidier. You should have a look for them.
Post #586291 19th Dec 2016 7:50am
mactheknife
Thanks Roddy, just been having a look on their site
Post #586440 19th Dec 2016 10:47pm
Bluest
Just make sure you disconnect the battery before going anywhere near that stud on the alternator. I speak from experience Thumbs Up 2007 110 TDCi Station Wagon XS
Post #586442 19th Dec 2016 10:51pm
mactheknife
Hahaha, noted!
Post #586443 19th Dec 2016 10:54pm
Scrawf
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Tamar Blue
Post #586444 19th Dec 2016 11:00pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
By "Gegio" from defendertricks.com
https://defendertricks.com/2012/03/01/solu...che-fonde/
and youtube video :
 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #586457 20th Dec 2016 12:27am
mactheknife
Thank you Marco.
Post #586458 20th Dec 2016 12:35am
Theater
mactheknife wrote:
Thank you Marco.
Wink Marco
Post #586462 20th Dec 2016 12:50am
